tial 38mm wastegate spring color - psi ??
i have 2 38mm wastegate springs, i have a blue spring and black. anyone know the psi on those?
Re: tial 38mm wastegate spring color - psi ?? (Turbo_y8)
SPRING RATE GUIDE
38mm/41mm Wastegate
0.25 Bar - 3.63 psi - Small Yellow
0.4 Bar - 5.80 psi - Small Red
0.5 Bar - 7.25 psi - Small Green
0.6 Bar - 8.70 psi - Small Blue
0.7 Bar - 10.15 psi - Large Yellow
0.8 Bar - 11.60 psi - Large Red
0.9 Bar - 13.05 psi - Large Green
1.0 Bar - 14.50 psi - Large Blue
I don't see a black so I have no idea.
Modified by genocide43110 at 7:26 PM 1/10/2007
38mm/41mm Wastegate
Re: tial 38mm wastegate spring color - psi ?? (SinglecamMitch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SinglecamMitch »</TD></TR><TR><TD CLASS="quote">Back from the dead... What psi is the black spring? </TD></TR></TABLE>
it's a BOV spring, not for wastegate use
http://www.tialsport.com
If it's not in there... it's not a tial part.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SinglecamMitch »</TD></TR><TR><TD CLASS="quote">well it was in a wastegate... anybody got a clue on what psi this guy would run?? seems pretty stiff</TD></TR></TABLE>
it's not a tial spring, you can't use a BOV spring in a wastegate
Re: tial 38mm wastegate spring color - psi ?? (TiAL)
i understand that but whos to say it wont work... its the same size as a small spring so i might actually push some psi that i could use... jw
rsintegra
05-23-2006 11:04 AM
