Quick ??? SOMEONE HELP???????
Old Jan 9, 2007 | 11:06 AM
jarven93's Avatar
Default Quick ??? SOMEONE HELP???????
i have a turbo'd civic D16z6 motor and want to go 15 lbs of boost wwhat injectors are a good cc to handle 15 lbs boost my choices are RC 440cc RC 550cc or RC 750cc the prices diff. is only about 30$ between the 440 and the 750s so any help plz thank you
jared
Old Jan 9, 2007 | 11:08 AM
Boosted B6teen's Avatar
Default Re: Quick ??? SOMEONE HELP??????? (jarven93)
Get the biggest ones possible. They will come in handy when you decide to move on to bigger and better things Is this a built motor or stock?
Old Jan 9, 2007 | 11:10 AM
Speed Infliction's Avatar
Default Re: Quick ??? SOMEONE HELP??????? (Boosted B6teen)
all depends on hp.
Old Jan 9, 2007 | 11:14 AM
jarven93's Avatar
the motor is built rod pistons crank. the head is stock the ignition all msd external coil all that good stuff and fuel mangment is a VAFC-2 the pistons were rated to max out at 20 lbs boost so i want to stay in the 15lbs so i dont want to get injectors that are to much in riching the motor out wise ?? and what kinda fuel pump and regulater and rail should i look at or do i even need to what stock parts will work with 15 lbs boost??
Old Jan 9, 2007 | 11:19 AM
If its a built motor dont get the smaller ones, get the 750s, but the first thing I would do is ditch the V-AFC and use some real engine managment. No reason to risk your built motor on it. Just my .02 cents....
Use a Walbro pump and leave your regulator and fuel rail stock, you dont need to upgrade those yet...
Old Jan 9, 2007 | 11:21 AM
jarven93's Avatar
what would you suggest for a fuel managment??
Old Jan 9, 2007 | 11:53 AM
Crome would be my first choice, since its so cheap, but you also have many other choices, Neptune, Hondata, AEM ect. Ive just seen/heard about to many cars blowing on the V-AFC hack.
Old Jan 9, 2007 | 12:55 PM
morgan@synapse motorsport's Avatar
very important get real engine management as listed in this guys post.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted B6teen &raquo;</TD></TR><TR><TD CLASS="quote">Crome would be my first choice, since its so cheap, but you also have many other choices, Neptune, Hondata, AEM ect. Ive just seen/heard about to many cars blowing on the V-AFC hack.</TD></TR></TABLE>
and i would go with the 750's
zbower7
Jun 12, 2004 09:12 PM
boost fed ls
Nov 4, 2003 09:03 PM
low-tech assassin
Oct 21, 2002 04:48 AM
fast[R]
Apr 17, 2002 02:50 PM
