Safe Boost
Old Jan 5, 2007 | 11:22 AM
wantasol's Avatar
Default Safe Boost
I'm wondering what you all think is a safe boost level to stay at for pump gas. I know it depends on the exact set up and tune, but heres what i'm running. I was thinking 16-17 psi should be alright. What do you all think? Also, any estimates on what hp it should make? Thanks in advance!
-d16y8 shortblock - stock bore, Crower rods, SRP pistons(9.0:1), Block gaurd, Balanced rotating assembly, z6 oil pump, etc
-cometic head gasket
-arp studs
-d16z6 head - ported, zex 59300 cam, upgraded springs, retainers, locks, adj. timing gear
-sc61 turbo and custom top mount manifold
-1000cc injectors
Old Jan 5, 2007 | 04:07 PM
wantasol's Avatar
Default Re: Safe Boost (wantasol)
also the engine does have a block gaurd installed in it.
Old Jan 5, 2007 | 08:23 PM
boostedcivicsir's Avatar
Mr. Badwrench
its all in the tuneup, i had 17psi on my old drag kit, and also did it with my f-r kit. we were way conservative both times.
Old Jan 8, 2007 | 12:11 PM
wantasol's Avatar
Default Re: Safe Boost (boostedcivicsir)
Any guess on the hp for a set up like mine?
Old Jan 8, 2007 | 01:17 PM
WickedHonda00's Avatar
Assuming your motor responds to that turbo...I'd say 350whp would be reasonable, 400whp should be at your finger tips-- but your powerband is probably going to suck, IMO. Regardless, you car should haul. Oh yeah, psi isn't what you measure your engine's durability by. You measure in hp. I'd imagine you could do 350-400 pretty reliable, but I don't know a whole lot about D series sleeves, so I can't tell you when enough is enough.
Just remember, 17psi from a GT28RS, T3/T4 50, 54, 57, and 60 trim, or any other typical turbo doesn't equate to the same stress output as 17psi from an sc61. In fact, every different turbo will unload a different amount of stress on your motor at the same boost level.
Old Jan 8, 2007 | 05:47 PM
wantasol's Avatar
Default Re: Safe Boost (WickedHonda00)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WickedHonda00 &raquo;</TD></TR><TR><TD CLASS="quote">Assuming your motor responds to that turbo...I'd say 350whp would be reasonable, 400whp should be at your finger tips-- but your powerband is probably going to suck, IMO. Regardless, you car should haul. Oh yeah, psi isn't what you measure your engine's durability by. You measure in hp. I'd imagine you could do 350-400 pretty reliable, but I don't know a whole lot about D series sleeves, so I can't tell you when enough is enough.
Just remember, 17psi from a GT28RS, T3/T4 50, 54, 57, and 60 trim, or any other typical turbo doesn't equate to the same stress output as 17psi from an sc61. In fact, every different turbo will unload a different amount of stress on your motor at the same boost level.</TD></TR></TABLE>
Yeah thats why I posted up the set up. I know it depends on your exact set up. The powerband actually feels good in the car right now and its on low boost.
Old Jan 9, 2007 | 06:51 AM
When does it start to pull hard?
killerB16A
Oct 5, 2009 07:10 AM
924doorEG
Mar 9, 2008 11:01 PM
JDM97EK
Dec 18, 2006 02:31 PM
pip9
Sep 17, 2003 06:49 PM
gigantor
May 9, 2002 04:42 PM
