Nitrous Rings????
Old Jan 7, 2007 | 03:46 PM
VolkswagenWHO!!!'s Avatar
Default Nitrous Rings????
Is there anyone out there who makes specail piston rings for nitrous on oem honda pistons? For H22 type s pistons?
Old Jan 7, 2007 | 04:25 PM
Default Re: Nitrous Rings???? (VolkswagonWHO!!!)
Bump for some info!
Old Jan 7, 2007 | 06:42 PM
RedEj8's Avatar
I dont think there as any such thing as a "nitrous ring". Your best bet would be oem or hastings rings for oem pistons. If you get aftermarket pistons then use the rings they supply.
Old Jan 7, 2007 | 06:47 PM
NJIN BUILDR's Avatar
Default Re: Nitrous Rings???? (RedEj8)
JE makes a hardened iron/manganese coated ring for nitrous but only in 4" and up.I've never seen them in honda sizes.
Old Jan 7, 2007 | 06:52 PM
Default Re: Nitrous Rings???? (NJIN BUILDR)
Yea when i said nitrous rings i meant like something alittle more durable then stock. Ive searched and searched and havent found anything.
Old Jan 7, 2007 | 07:04 PM
The oem rings are as strong as the stock pistons.
Old Jan 7, 2007 | 07:18 PM
JSpin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The oem rings are as strong as the stock pistons.</TD></TR></TABLE>
yep, you'll be at the mercy of the oem pistons more so than the rings. if you ever do a build with an aftermarket piston, just speak with whoever makes the piston.
Clerique
Oct 4, 2008 05:14 PM
quik1
Jun 19, 2004 06:33 PM
quik1
Jun 9, 2004 07:48 PM
Hoosier Daddy
Nov 7, 2003 12:53 PM
99B16Si
Dec 25, 2002 08:39 PM
