should i drive?
Old Jan 8, 2007 | 09:45 AM
jdm2teg's Avatar
Default should i drive?
well guys my integra was tuned berofe and then i changed my 440 cc to 1000 cc and added edelbrock intake manifold and a stage 4 cc slutch on it. i know i have to retune it but the question is can i drive it to the tunning place? is it safe? i know i am not gonna drive stupid and probally shift every 3k rpm. but with the new injector i am not even sure the car will even stard because it will be dumping too much fuel right? well what you guys think i should do. thanks.
Old Jan 8, 2007 | 09:46 AM
.nate's Avatar
I would put the 440cc injectors back in, drive to the dyno and slap the 1000cc's in there.
Old Jan 8, 2007 | 09:53 AM
b18sihatch's Avatar
Default Re: (.nate)
x2
Old Jan 8, 2007 | 09:55 AM
jdm2teg's Avatar
Default Re: (b18sihatch)
damm i just sold those so i can get some money to tune my car. . you guys think the car will even stard with the 1000?
Old Jan 8, 2007 | 10:38 AM
wade's Avatar
Default Re: (jdm2teg)
dont drive on the 1000s. You can wash out your cylinder walls with excess fuel killing the oil and its lubrication on the cylinder walls resulting in premature piston/ring contact and possible failure.
Old Jan 8, 2007 | 02:36 PM
coneheadsracing's Avatar
Default Re: (wade)
Can you get a hold of your tuner, and ask for a basemap for the 1000cc injectors?
Old Jan 8, 2007 | 03:57 PM
jdm2teg's Avatar
Default Re: (coneheadsracing)
no but i decided ill jus have a friend tow me thier with his car. i wonder if i can even stard the car. i havent starded it for like 6 month. i took nthe motor out and washed it, painted it, did the oil change and havent starded it. will it affect anything by just starding it?
Old Jan 8, 2007 | 07:19 PM
HiProfile's Avatar
440's to 1k's is like jumping from stock 240's to 550's. The ecu can manage a 30% jump by itself, a 2x jump with an VAFC, you're looking at a 2.27x increase.
You'd be better off slapping the stock 240's in there, pulling the chip, and taking a clamp off one coupling (bleed any boost that you build). Drive to the dyno, swap to the new components, then be happy. Around here you can rent car dolleys for $37/day, so if you have access to a truck, you could just pull it. I pulled a 95 EX with a newer ford ranger for over an hour, which was just a tad small for the job.
mouab18c1
Oct 1, 2012 08:40 AM
.BigSexy
May 19, 2007 10:54 AM
HondaIntegraR
Mar 8, 2005 01:35 PM
IN VTEC
Jul 24, 2002 09:28 PM
