a far fetched question
Old Jan 5, 2007 | 01:08 AM
cantaffordaccord's Avatar
Default a far fetched question
has anyone ever tried to compound turbo charge a honda? if so what were the results?
I know of one guy who was local but moved though it deffinatley wasnt a honda he was running a compound setup on his cummins deisel
http://www.coldspeed.net/forum...=3830
heres his dyno video
http://www.coldspeed.net/forum...=4775
not shure where his #'s are but they were something like 460hp and 1200tq
just kind of wondering what the results would be on a 4cyl honda
thanks guys
Old Jan 5, 2007 | 05:44 AM
JShull's Avatar
There is a guy that did this on the Homemade turbo boards. I think that it is actually in the projects section.
Old Jan 5, 2007 | 10:24 AM
Default Re: a far fetched question (cantaffordaccord)
bump I dug through those forums a bit but could not find any of this info
is anyone or has anyone ran a setup like this on the boards?
Old Jan 5, 2007 | 12:29 PM
boosted92's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cantaffordaccord &raquo;</TD></TR><TR><TD CLASS="quote">bump I dug through those forums a bit but could not find any of this info
is anyone or has anyone ran a setup like this on the boards?</TD></TR></TABLE>
Diesels are completely different from a gasoline motor. You run 150+ pounds of boost into a diesel and you don't have to worry about pinging, because the motor runs off of detonation. Compound turbocharging is a good way to introduce a TON of heat into the air and detonate the expletive out of a gas motor.
Old Jan 5, 2007 | 12:45 PM
TunerN00b's Avatar
While its a neat idea on concept, go pop your hood and tell me where you'd manage to fit 2 complete turbochargers in there. If you can do that, then tell me where you'd fit all the necessary plumbing to go with them. I just can't see stuffing all that extra hardware under the hood, except maybe an Accord I4, since there's obviously room to stuff the V6 in there.
Old Jan 5, 2007 | 01:16 PM
vtec.dc2's Avatar
Default Re: a far fetched question (TunerN00b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TunerN00b &raquo;</TD></TR><TR><TD CLASS="quote">
While its a neat idea on concept, go pop your hood and tell me where you'd manage to fit 2 complete turbochargers in there. If you can do that, then tell me where you'd fit all the necessary plumbing to go with them. I just can't see stuffing all that extra hardware under the hood, except maybe an Accord I4, since there's obviously room to stuff the V6 in there.</TD></TR></TABLE>
it has been done as previously posted. if people had poor perforamnce using single turbo you'd see this more often. one turbo is good enough for most. i'm sure theres a way to make any setup very efficient, single turbo, twin or sequential or turbo/supercharged.. its all in how much time/money you want to spend. still not even close to what i see inside hybrid forum. mid engine sols and integras, v8 prelude, rwd/awd integra..
Old Jan 5, 2007 | 07:21 PM
I do actually own the 2001 accord sedan thats why I ask thers lots of room in there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted92 &raquo;</TD></TR><TR><TD CLASS="quote">
Diesels are completely different from a gasoline motor. You run 150+ pounds of boost into a diesel and you don't have to worry about pinging, because the motor runs off of detonation. Compound turbocharging is a good way to introduce a TON of heat into the air and detonate the expletive out of a gas motor.</TD></TR></TABLE>
I figured the heat would be there
also I would only like to run a max of 20psi not saying I am going to do this project but I am interested because I will eventually fully build and boost fall this year or last the car will never be sold period (love the car)
I was thinking if I were to go this route I would likely use a small turbo that could give me boost near off idle 1500-2000 rpm then using a turbo that would see boost at 2500rpm to redline witch is somewhere near 7000rpm stock of course depending on how much air is being compressed by the smaller turbo I dont really know too much about turbocharging but I have done a good bit of homework and could build my own kit from scratch this idea has just been in the back of my head
zxc4
Aug 8, 2007 08:23 AM
. O M E G A
11
Dec 21, 2005 10:24 AM
nardiwheel
Aug 3, 2005 11:02 PM
donniebrasco
Aug 29, 2004 07:12 AM
RyanAutry
Oct 26, 2003 09:25 PM
