boost stopped building
Old Jan 8, 2007 | 03:45 PM
vladd's Avatar
Default boost stopped building
i just finished my turbo install on my 99 gsr. i drove it a couple times without any problems, though i didn't rev it very high. one time i drove it, parked for a few minutes, and when i started the car back up the boost stopped building. a few minues previously everything was working just fine. i already checked for loose piping or vaccum hoses. here's my setup:
t3/t4 turbonetics turbo
revhard log manifold
tial 38 mm wg
hks evc (the original one)
vortech bov
what could the problem be?
Modified by civicdxtyper at 6:14 PM 1/8/2007
Old Jan 8, 2007 | 04:19 PM
Synapse Motorsport's Avatar
Default Re: boost stopped building (civicdxtyper)
Maybe the wastegate is stuck partially open.
Old Jan 8, 2007 | 04:21 PM
vladd's Avatar
Default Re: boost stopped building (Synapse Motorsport)
how would i check for that? i already tried taking the top of the wg off, the spring seemed to be seated correctly and everything.
Old Jan 8, 2007 | 04:54 PM
komat's Avatar
if its a open dumptube. put your hand near the opening of hte dumptube and feel if theres any hot air coming out
Old Jan 8, 2007 | 05:11 PM
vladd's Avatar
Default Re: boost stopped building (komat)
the dp is open. i just started the car and didn't feel any air coming out at idle from the dp. the bov seems to be closed, isn't it supposed to be open at idle? when i stick my hand in it i can't feel any air moving and the valve feels closed.
Old Jan 8, 2007 | 05:30 PM
komat's Avatar
have you checked if the turbo spins freely?
Old Jan 8, 2007 | 05:36 PM
vladd's Avatar
yup. i can see it spin when idling. i can also spin it by hand.
Old Jan 8, 2007 | 05:55 PM
vladd's Avatar
what're the chances of the ebc taking a ****? i know its pretty old. i'm thinking maybe the valve got stuck or something? its wierd cuz i parked the car for like 10 minutes, and it just stopped going into boost.
Old Jan 8, 2007 | 06:22 PM
HamiltonRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">what're the chances of the ebc taking a ****? i know its pretty old. i'm thinking maybe the valve got stuck or something? its wierd cuz i parked the car for like 10 minutes, and it just stopped going into boost.</TD></TR></TABLE>
Run the WG off spring only.
Old Jan 8, 2007 | 07:46 PM
vladd's Avatar
Default Re: boost stopped building (HamiltonRex)
just tried that, still nothing. the boost needle will get close to 0 and just stay there when i rev it up.
Old Jan 8, 2007 | 08:03 PM
ccivic's Avatar
wait.. are you actually driving the car building boost or are you just revving it in neutral? if you're just revving it in neutral, this doesn't surprise me.. there usually isn't enough load to build boost.
Old Jan 9, 2007 | 03:46 AM
vladd's Avatar
Default Re: boost stopped building (ccivic)
yes, i am driving it. i know that it won't build boost in neutral. i've revved it to about 7k rpm when driving without it reaching the 0 mark.
Old Jan 9, 2007 | 04:48 AM
95dc2teg's Avatar
make sure u check all vacuum lines and intercooler pipes
edit....can u hear the turbo spool while driving?
Old Jan 10, 2007 | 06:19 AM
vladd's Avatar
Default Re: boost stopped building (95dc2teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2teg &raquo;</TD></TR><TR><TD CLASS="quote">make sure u check all vacuum lines and intercooler pipes
edit....can u hear the turbo spool while driving?</TD></TR></TABLE>
so i see that you're one of those that replies after reading just the topic.
Old Jan 10, 2007 | 11:39 AM
litovi3tboi503's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">yes, i am driving it. i know that it won't build boost in neutral. i've revved it to about 7k rpm when driving without it reaching the 0 mark.</TD></TR></TABLE>
Hmmm.. i dont know sounds like you got boost lag.. you must have the new gt50r.. you wont get boost till 9.5k rpm no im jp i dont know.. sounds weird.. im thinking it has to do something with the wastegate or you should check your silicone hose again...
Old Jan 10, 2007 | 11:47 AM
Jamisonb's Avatar
Make sure your boost gauge isnt broken. Mine was and i thought i had a boost leak for 2 weeks!
Old Jan 10, 2007 | 11:50 AM
Default Re: (Jamisonb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jamisonb &raquo;</TD></TR><TR><TD CLASS="quote">Make sure your boost gauge isnt broken. Mine was and i thought i had a boost leak for 2 weeks!</TD></TR></TABLE>
haha so you looked at your gauge... just to see if you were boosting? cant you tell by the way it pulls you back? my gauge reads all wacky but i only looked at it 4 times since i got it..
Old Jan 10, 2007 | 12:09 PM
95dc2teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicdxtyper &raquo;</TD></TR><TR><TD CLASS="quote">so i see that you're one of those that replies after reading just the topic. </TD></TR></TABLE>
well if u have already checked everything and u can hear the turbo spool and ur still arent building boost....then it must be something stupid like a vacuum leak or intercooler pipes, so check again.....UNLESS u decided to take it to 7k without any sort of tune and ur blew ur motor
chriscool888
Jul 5, 2011 12:22 AM
turboek97
Sep 12, 2008 12:58 AM
b18cEF9
Jul 24, 2005 01:18 AM
TA Performance
Mar 15, 2005 07:29 PM
18psi sohc
Jan 17, 2005 11:38 AM
