Do integras have exhaust bolts or studs?
My 97 integra ls has exhaust manifold bolts, I was thinkin and pretty much every other car i've worked on had exhaust manifold studs...Since I have bolts, it seems to strip out the head threads. which sucks. Where can I get studs?
Re: Do integras have exhaust bolts or studs? (spoolin_teg)
early b-series had all studs for the exhaust flange. In later years such as your 97 they started using mostly bolts. This is cheaper for the manufacturer and saves them a few pennys per engine. Only the two outside holes have studs right?
I like to use full studs like they used to come from the factory.
acura or honda.... most b-series ive seen have the two outer as studs. just order as many of those as u need and also the nuts... honda maybe cheaper even though its the same part..
Yeah you could get the rest right from acura, but they are expensive. About 2-3 bucks each for the stud and another 1.50-2 each for the oem locking nuts! I usually take them off old motors before they get scraped!
sleepencivic
03-22-2011 06:39 PM
