Ramhorn Turbo Mani, what turbo are you running?
Re: Ramhorn Turbo Mani, what turbo are you running? (JSPECSIR)
T3/T4 Master Power, right? How much boost are you running? Let me guess, no boost creep, right?
Re: Ramhorn Turbo Mani, what turbo are you running? (Synapse)
i was running a t3/t67 -38mm wg. no boost creep issues, with 3inchdp/2.5inch exh. another HT user currently has the setup, but is using a BB t3/t67HO
old build thread
new owner of my old setup.
and here too!
Modified by dturbocivic at 7:54 AM 1/8/2007
old build thread
and here too!
Re: Ramhorn Turbo Mani, what turbo are you running? (Team_Carnage)
Precision GT30R with an AFI Ramhorn. Don't have pics at the moment, but fitment is great.
Re: Ramhorn Turbo Mani, what turbo are you running? (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic »</TD></TR><TR><TD CLASS="quote">i was running a t3/t67 -38mm wg. no boost creep issues, with 3inchdp/2.5inch exh. another HT user currently has the setup, but is using a BB t3/t67HO</TD></TR></TABLE>
So there was no creep even just off the gate spring @ 11lbs
Im just wondering as im going with an sc61 and i have an sls ram horn and its flanged for a 38 and was wondering if id get away with the 38mm or if ill have to run a 44mm
Check my sig for some pics of the ramhorn and turbo
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Re: Ramhorn Turbo Mani, what turbo are you running? (DfwBB6)
Spoolin' ramhorn manifold...problem is, it was on an Integra which has a higher radiator support than my EK. on me for not researching before putting it on...
Re: Ramhorn Turbo Mani, what turbo are you running? (ccivic)
For the guys with GT series turbos, what's the lowest boost that you're making on what spring?
KOBE IS GOD
Re: Ramhorn Turbo Mani, what turbo are you running? (boostincoupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe »</TD></TR><TR><TD CLASS="quote">Spoolin' ramhorn manifold...problem is, it was on an Integra which has a higher radiator support than my EK. on me for not researching before putting it on...
Dang you cut your radiator support. what would happen if you would have put some kind of elbow there ? Your setup still looks great though.
I am using a sc61 with a ramhorn and a 38mm gate 12 psi with no creep and 18 psi with no problems.Car has been down for a while though?
Dont mind the fake valvecover it was ditched for an oem
Modified by siblues at 1:57 AM 1/9/2007
Re: Ramhorn Turbo Mani, what turbo are you running? (siblues)
im running a rld manifold that was made 3 or 4 years ago
dont mind that filter ont he first pic. was using it to start up my fresh build motor
Re: Ramhorn Turbo Mani, what turbo are you running? (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">im running a rld manifold that was made 3 or 4 years ago
</TD></TR></TABLE>Sorry OT, but did you or do you have a problem w/ the oil return with the turbo sits like that? the return is almost sideway like 90* thanks. I use Full-race ramhorn mani and t3/ 60-1 turbo w/ 40mm wg.
Re: Ramhorn Turbo Mani, what turbo are you running? (V-SPEC 1)
Drunken redneck neighbor with a welder (tm) manifold and IHI RHB5
Fits pretty sweet, too.
Racecars are all good fun and all, but 14 second Subaru Justys make me giggle. Wish it were mine.
Re: Ramhorn Turbo Mani, what turbo are you running? (eastcoast_ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eastcoast_ej »</TD></TR><TR><TD CLASS="quote">
Check my sig for some pics of the ramhorn and turbo</TD></TR></TABLE>
yea, i had a 2.5inch exh on the car too, maybe if it was open dp or 3inch i would have more of a chance of geting boost creep.
