?"s on my h23a1 engine build
i've been gathering parts and info on building the h23a1 but don't know if i'm doing it right. if anyone can help pease do so. here is what's done so far, engine is sleeved with darton flanged sleeves(87.5 mm), everything else is awaiting install, carillo rods, cp pistons, kms high flow oil pump, egr plate, crower cams, crower dual valve springs, titanium retainers, skunk 2 cam gears, .5 mm oversized valves, valve guides and seals-etc, koyo racing radiator, arp stud and main bolts, 3 bar map sensor, 550 rc injectors, aem fuel rail, need a fpr, king bearings for rods and crank, knifing crank, rps clutch, flywheel ?, rebuilding tranny w quaife lsd, stage 2 axles, hondata s300, p70 ecu, drag turbo kit(57 trim), blitz bov, tial wg(38mm), 255 lph walbro fuel pump, still wondering what msd to go with?, all necessary seals and gaskets, going to go with a test pipe conversion and 3" exhaust, turbo and downpipe heat guards/wrap, silicone cooling hoses, of course a good tune, o ya and a greddy profec b spec 2, auto meter gauges(oil temp, af ratio, boost). is there anythng i'm forgetting??????
i've been gathering parts for the last 2 yrs and coming close to completion. i need to know if this is going to be a good set up and if i need to make changes please let me know now so i can change it while i can. i was planning to use the stock intake manifold since it's got iab valves and just upgrading the throttle body with a spacer, if i can find one. please give all expert advice, thanks.
Re: ?"s on my h23a1 engine build (mrkal)
The set-up sounds good but build you listed sounds like the motor can handle in the range of 400whp. The Drag kit is going to limit you to making that much power.
What is your goal exactly in terms of power?
Re: ?"s on my h23a1 engine build (PrecisionH23a)
my goal is your guess exactly. i'm shootig for 400 whp but will be satisfied with 350. you think the drag kit will set me back alot?? i knew i should have went with the gt30r turbo. what do youthink i'll get ot of the drag kit????
