84 trim exhaust on a gs-r
i have a built gsr
the turbo has a 84 trim exhaust
i am running a afi topmount manifold w/ a 4inch down pipe/ 4 inch exhaust
1200 cc injectors
i dont know much about turbo trim or sizing
someone give me an idea on if it will be too big or ok.. i have heard both ways but lmk what everyone thinks
Modified by tunedhonda-ata at 8:45 AM 1/11/2007
1200 cc injectors
Re: 84 trim exhaust on a gs-r (tunedhonda-ata)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunedhonda-ata »</TD></TR><TR><TD CLASS="quote">i have a built gsr
1200 cc injectors
Modified by tunedhonda-ata at 8:45 AM 1/11/2007</TD></TR></TABLE>
Can't answer that question without knowing at least the inducer or exducer size of the turbine wheel. What turbo do you have?
Edit: WOW, don't bump the thread 17 minutes after you made it, someone will get to it eventually seriously
1200 cc injectors
Re: (tunedhonda-ata)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunedhonda-ata »</TD></TR><TR><TD CLASS="quote">sorry im a noob. it is a t60-1 the wheel is 60.5 mm it has a 84 trim ex side</TD></TR></TABLE>
Is this a T3/T4 or staright T4 turbo? When you say it has a 60.5mm, that is your compressor wheel or turbine wheel? What KIND of turbo is it and where did you buy it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tunedhonda-ata »</TD></TR><TR><TD CLASS="quote">t3/t4 60.5 compressor wheel my friend had it on a 2.0 eclipse</TD></TR></TABLE>
The compressor wheel is irrelavant, I only asked since you didn't state at first if it was the turbine or compressor wheel that was 60.5mm. There is no way to tell you if an 84 trim is too big or small without knowing either the measurements of the inducer or exducer of the turbine wheel
antoneexx
10
12-21-2006 08:14 PM
