I Need Some Help
Old Jan 7, 2007 | 05:36 PM
EfSedanLove's Avatar
Default I Need Some Help
allright i got my car running again because last time the timing belt snapped off and ate the valves. right now i have:
91 Civic LX
obd0
D16y7
EBAY TURBO KIT!
T3/T4 TO4E (Ebay!)
SUPER 38MM WASTEGATE W/Softest Spring in (Ebay!)
SUPER 680mm X 460mm X 180mm INTERCOOLER (Ebay!)
SUPER RACE TURBO MANIFOLD STAINLESS STEEL (Ebay!)
Lx Trans
Pm6 ECU
D16A6 IM switching to D15b7 IM W/LS TB
2.5" Piping W/HUDGE Resonator
FMU (EBAY)!
Stock Injectors
obd2 Map W/Missing Link and Ghettofide
thats my gay setup, anyways my question is whats the easiest way of tunning it, also my stock fuel pump is about to take a **** on me and if i was to change it will it make a different. I dont knoe how accurate AF gauges are but sometimes i get a almost lean reading and it scares me. I was wondering if a different o2 sensor will do anything, also because my check engine light turns on because of the o2, Why? and also do i mess with my dizzy? and the obd0 map sensor and obd2 map sensor wire set up the same because im running a obd2 map sensor w/missing link, basically ghetto rigged and it runs better than the oem map sensor because the oem idle surges and rpms are slow when u release the gas pedal.
Modified by EfSedanLove at 3:21 PM 1/8/2007
Old Jan 7, 2007 | 09:17 PM
Default Re: I Need Some Help (EfSedanLove)
bump
Raymond94
Mar 11, 2012 05:02 PM
allshownogo
Jan 25, 2009 08:56 PM
Evilparadize
Feb 11, 2008 08:00 AM
jordan_civic
Aug 11, 2007 06:54 AM
EfSedanLove
Jan 12, 2007 07:26 AM
