What kind of signal is a tach signal?
what is it like pulse per min?
and what the difference between. 4,6,8 cyl?
this is sord of a dumb question but i cant find it anywhere
Re: What kind of signal is a tach signal? (tony1)
Yeah, the if you view the ignitor triggering the primary coil on a scope with the on/off, on/off that is what basically creates your tach signal. That's why the tach jumping around is an immediate indicator of an ignitor problem.
Re: What kind of signal is a tach signal? (fmfkid250)
the only difference between 4,6,8 is the way the tachometer is calibrated to convert the number of reference pulses into engine speed using rpm display on the tachometer. It takes 2 crankshaft revolutions to fire all the cylinders once. On a 4 cylinder, that would mean 4 pulses is 2 rpm. At idle speed if the tach is recieving 1600 ref pulses pm it converts it to 800rpm. Now On a 6 cylinder 1600 ref pulses pm would mean about 530RPM.... you get the point.
Re: What kind of signal is a tach signal? (Flexmyrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flexmyrex »</TD></TR><TR><TD CLASS="quote">the only difference between 4,6,8 is the way the tachometer is calibrated to convert the number of reference pulses into engine speed using rpm display on the tachometer. It takes 2 crankshaft revolutions to fire all the cylinders once. On a 4 cylinder, that would mean 4 pulses is 2 rpm. At idle speed if the tach is recieving 1600 ref pulses pm it converts it to 800rpm. Now On a 6 cylinder 1600 ref pulses pm would mean about 530RPM.... you get the point.
thats what i was looking for, thanks alot!!!
A.D.D. Racer
05-24-2006 09:02 AM
Average Al
01-22-2004 04:13 PM
