NEED HELP ASAP!!! Trying to BOOSTTTTT!!!
Old Jan 10, 2007 | 12:56 PM
Anti-Drama Queens's Avatar
Default NEED HELP ASAP!!! Trying to BOOSTTTTT!!!
motor was just built and is smoking..we've narrowed it down to the turbo and the feedline and return line MIGHT be swapped on accident. Would that cause the oil to come of the intake side of the turbo and also is there a certain position that the turbo must sit so the oil is exiting the turbo correctly?
Old Jan 10, 2007 | 01:13 PM
97CWITR's Avatar
Default Re: NEED HELP ASAP!!! Trying to BOOSTTTTT!!! (anti-jdm)
Your oil return line is probably to low on your oil pan so its not draining, just filling the line up.
Post a pic of your oil return and pan.
Old Jan 10, 2007 | 01:35 PM
ill b able to get pics tommorrow..but basically right now the return is sitting on top and going to the oil pan...and the feed is on the bottom...im not sure is it supposed to be the other way around or not? the problem is that its smoking aloooot and oil is leaking out of the the turbo (intake side)
Old Jan 10, 2007 | 01:41 PM
coneheadsracing's Avatar
Default Re: (anti-jdm)
Yes, the return line uses gravity, it has to be on the bottom.
Old Jan 10, 2007 | 02:30 PM
ok..so like just to make sure, how do i tell which fitting is for which...is there any way i can distinguish that? i dont know which hole is for the feed and which hole is for the return...is one bigger than the other? cause i keep getting the same problem over and over again...***** smoking alot and oil leaking out of the turbo...oil was even coming out of the exhast
Old Jan 10, 2007 | 02:36 PM
93CX's Avatar
wow.. i wonder if you killed your seals from running like that. who the hell installed it?
Old Jan 10, 2007 | 02:42 PM
well there is oil getting in it and out..but just wanna make sure its the correct way
Old Jan 10, 2007 | 02:44 PM
it was never put into full boost or any boost ..and hasnt even been driven yet
Old Jan 10, 2007 | 06:27 PM
The feed hole, is typicaly smaller then the return. Also, the return is usualy setup for a flange, or a 1/2 inch or so fitting. What turbo, any pics? Having it upside down if you did, you pressurized the turbo, again what turbo. What size is your feed line, what size is your return line. Too big of a feed line will cause problems too. This i know first hand.
jprelude92
Aug 30, 2008 07:12 AM
"00"R
Jun 21, 2007 10:48 AM
btech
Jun 16, 2007 07:17 PM
z6
Jun 3, 2004 11:03 AM
iperez
Jan 18, 2003 04:36 PM
