cometic head gaskets
Old Jan 10, 2007 | 08:05 PM
turbodegsi's Avatar
Default cometic head gaskets
what have you guys heard of these head gaskets???
i have one in my boosted car and was wondering because lately i've been running a little low on coolat and car is kind of overheating every once in a while.. i'll top it off then next week same thing.
or do you think it's because the intercooler is blocking the radiator???
i know that might have something to do with it but what do you guys think???
Old Jan 10, 2007 | 08:17 PM
B18 CYA's Avatar
Try running the fan wire to ignition so it's constantly running. Might solve your overheating issue every once in a while. I've read a few threads about people having issues with cometic head gaskets and that oem ones are better... How true that is, I don't know.
On the other hand, I read more of cometic head gaskets blowing than oem ones.
Old Jan 10, 2007 | 10:34 PM
Ryan15's Avatar
Default Re: (B18 CYA)
I hear that too, but the simple fact that cometic is a proven company leads me to believe its user error actually amtter a fact ive been using an autozone headgasket for the last year no problems and the head has been off 3 times since then and i reused it no problems, now im boosting and im going to use a .054 cometic headgasket with GE head studs, so hopefully im luckier than the rest!
Ryan
Old Jan 11, 2007 | 10:27 PM
turbodegsi's Avatar
Default Re: (Ryan15)
bump
Old Jan 11, 2007 | 11:12 PM
boostaddict14's Avatar
Default Re: (turbodegsi)
i am a believer in cometic. i will be running one soon. i believe tha the cause of a cometic hg failure is
1. a warped head that wasnt shaved down prior to installing
2. improper install
Old Jan 12, 2007 | 03:29 AM
Boosted2K's Avatar
Default Re: (boostaddict14)
Cometic here, still holding strong
Old Jan 12, 2007 | 07:06 AM
ryan89crx's Avatar
my cometic works great
Old Jan 12, 2007 | 08:19 AM
AROD's Avatar
i use cometic gaskets for 4 year 400+hp no problems
Old Jan 12, 2007 | 08:27 AM
Golden Eagle's Avatar
Default Re: (ryan89crx)
most of our racers and street cars ran cometic gaskets at one time and were having problems that's why we started boring out the oem honda gaskets and we have found that they hold up much better the only time we sagest cometic is if you need a thicker gasket then stock
Old Jan 12, 2007 | 08:33 AM
tony1's Avatar
Default Re: (Golden Eagle)
I've seen both work, but i prefer honda gaskets.
Old Jan 17, 2007 | 04:07 PM
turbodegsi's Avatar
Default Re: (tony1)
theres no need to retorque them is there??
usually when i do head gaskets i never have to..
Old Jan 17, 2007 | 05:41 PM
92DAturboteg's Avatar
Default Re: (tony1)
How many of you spray your hg's with coppercoat?
Old Jan 17, 2007 | 05:54 PM
turbodegsi's Avatar
Default Re: (92DAturboteg)
i sometimes do depending on app or what i'm working with..
Old Jan 17, 2007 | 05:55 PM
turbodegsi's Avatar
oh what i mean about retorqueing is, i have the thick gasket with the plastic looking shim in the middle to thicken it..
Old Jan 17, 2007 | 06:07 PM
wip_customs's Avatar
Default Re: cometic head gaskets (turbodegsi)
Never had a problem with cometic i like em!
Old Jan 17, 2007 | 08:22 PM
wheelie's Avatar
Cometic and/or Felpro MLS are good gaskets. I use Copper Coat on them however, I spray Copper Coat on the layers, and front/back and let it get tacky before setting the gasket on the block and installing and torquing the head. Hope this helps. They work good!
AFAccord
Jun 14, 2009 03:00 PM
slomovr
Jan 16, 2009 12:28 PM
turbodegsi
Jan 10, 2007 08:41 PM
4th gen civic racer
Jan 19, 2005 04:28 PM
