difference in PR vitaras and OEM ones
does anyone know if there is a difference in the vitaras coming from puerto rico and the ones that are available from the stealership? i have a set of.5mm overbore vitaras ( that is apparently a size taht is only available from the dealership) and im wondering if there is a difference in the strength of these i have and the ones that people like FJT are selling out of PR
ive had a set of the PR ones before and there is an obvious appearance difference. the oem ones arent coated and the oil holes in the pistons are different
anyone know if its a different alloy?
thanks in advance
thanks in advance
Yes there is a difference. The OEM from the dealership are not made from the same material..and dont have the coating that the Y.C.P. ones have..
For once the replacement piston is way better than the OEM...OEM ones wont hold the same power as the Y.C.P. ones.
shurick
03-24-2006 11:59 PM
