Piston size?
Old Jan 20, 2007 | 11:45 AM
thollis97's Avatar
Default Piston size?
I have a d16y8 and I am going to bore the block. I was wondering how big should i bore it.
Old Jan 20, 2007 | 11:46 AM
doood's Avatar
been there done that
Default Re: Piston size? (thollis97)
are you resleeving?
Old Jan 20, 2007 | 12:51 PM
HiProfile's Avatar
Bore it as little as you can, based on what you can get for pistons, or are required to in order to get 'perfect' cylinders.
Its only OEM and SRP pistons that come off-the-shelf in 75.25mm size, aftermarket forged are 75.5mm unless you custom order them. Just make sure you get the pistons, THEN bore it. You want to size the bores to the pistons, based on the piston mfg's recommended clearances.
Old Jan 22, 2007 | 02:01 PM
thollis97's Avatar
Default Re: Piston size? (HiProfile)
How much of a horse power increase will come with the boring?
Old Jan 22, 2007 | 02:11 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thollis97 &raquo;</TD></TR><TR><TD CLASS="quote">How much of a horse power increase will come with the boring?</TD></TR></TABLE>
very little unless you go big with the bore
Old Jan 22, 2007 | 05:21 PM
thollis97's Avatar
Default Re: Piston size? (doood)
I have a block that is going to need all new internals. should i might as well bore it out because it needs all of it. and should i sleeve it instead?
Old Jan 22, 2007 | 05:22 PM
doood's Avatar
you cant go too much over stock without sleeving first
raverx3m
Jun 10, 2014 10:55 AM
dritan
Jan 7, 2011 07:18 AM
Teamdiesel
Aug 6, 2008 06:51 PM
lemongreenhatch
Sep 29, 2004 09:13 AM
roydogg
Aug 6, 2003 06:49 AM
