Radiator Scoop?
Old Jan 21, 2007 | 04:30 PM
GoFastTshirts.com's Avatar
Default Radiator Scoop?
Hey guys, I have a question for all of you.
To help with cooling do any of you have a piece of sheetmetal blocking the front of the car next to the radiator to force air to pass the radiator? If so any pics? Is it worth it to do? I am thinking of making one to help out with cooling. Thanks
Old Jan 21, 2007 | 04:37 PM
HiProfile's Avatar
Default Re: Radiator Scoop? (GoFastTshirts.com)
From what i've seen, the non-ac cars like a CX came with them. IIRC, my 94 CX had it.
If you are having temp issues, I'd say use it. Otherwise, underhood temps will probably be helped a bit by not running it.
Old Jan 23, 2007 | 05:42 AM
Default Re: Radiator Scoop? (HiProfile)
anyone else have experiences with it?
Old Jan 23, 2007 | 05:49 AM
mike1114's Avatar
as said if your not rocking A/C then put a piece of sheetmetal there.
Air takes the path of least resistance. It is easier for air to go AROUND your radiator if there is a way, then go through the radiator.
Old Jan 23, 2007 | 05:58 AM
xsi-t's Avatar
On my last setup I ran a stock fan with a shroud on a PWR radiator. My coolant temps boosting were 187F - 192F, 192F - 195F driving and 198F - 202F sitting. I saw over 202F once. That's when my radiator hose slid off. It got up to 215F during a pass
-- Alpha
Old Jan 23, 2007 | 09:25 AM
Default Re: Radiator Scoop? (mike1114)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike1114 &raquo;</TD></TR><TR><TD CLASS="quote">as said if your not rocking A/C then put a piece of sheetmetal there.
Air takes the path of least resistance. It is easier for air to go AROUND your radiator if there is a way, then go through the radiator.</TD></TR></TABLE>
Yea I have no A/C.
Does anyone have a picture of it in a car? I have seen it here before but I cant find it in a search now.
prahaian
Jan 5, 2014 01:02 PM
Tootsie7944
Feb 9, 2012 01:56 PM
oovvutt
25
Dec 25, 2007 02:56 PM
envious1320
Mar 7, 2003 02:11 PM
EGh22aEG
Jan 9, 2002 06:37 PM
