How much whp before you need headstuds?
Re: How much whp before you need headstuds? (GetawayInMoscow)
i would get them anyways because you cant reuse stock ones and you can reuse arp's. they are good insurence so your head doesn't come up off the block. they are only about 115 bux or cheaper.
Re: How much whp before you need headstuds? (Synapse Motorsport)
I recommend them for all D-series motors...
Like a good fuel pumps, they are just good measure in my opinion.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">On a stock GSR? I guess the better question is how much whp did you have on stock head bolts....</TD></TR></TABLE>
you need head studs to start out with anyways or your head would go flying.
Re: How much whp before you need headstuds? (rice a roni)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice a roni »</TD></TR><TR><TD CLASS="quote">you need head studs to start out with anyways or your head would go flying.</TD></TR></TABLE>
nice try but no, the factory uses head BOLTS, this guy is considering converting to head STUDS. there is a difference. back on topic, im in the same boat, i think im just gonna do it.
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMej1 »</TD></TR><TR><TD CLASS="quote">now if i were to just change the bolts to studs would i need to change the head gasket also?</TD></TR></TABLE>
no. the studs go in the same holes the bolts normally do.
Re: How much whp before you need headstuds? (doood)
Yes anytime the headgasket gets tightened down you need to replace the head gasket when you open the head up again.
IMO: On a B series, if you are not going to open the head for internal changes the stock ones will probably be OK. On a D series I would change it above 250 or so HP. If you notice any head lifting issues it's a fairly simple fix, but you risk warping the head if not done.
turbochic
04-12-2003 05:55 PM
