hp limits on laskey race engine?
Old Jan 21, 2007 | 10:51 AM
94hatchvx's Avatar
Default hp limits on laskey race engine?
ok. i am starting to piece together my new build right now and im am looking to go big. i know i want to get sleeved but beyond that i dont know. i was looking at the laskey sleeved bottom ends they sell for like $3400. does anyone know wut the limit on those motors are. with the pauter rod sleeved set up.but then again im thinking of just piecing my own set up together. i was thinking b16 sleeved block bored to 81.5 or more, lightned ls crank micropolished,eagle h beams,wiseco 8:9:1 cr pistons(anyone know the power limit on wisecos?) with wiseco rings,arp hardwear and head studs,cometic head gasket,new oil pump water pump timing belt etc. , ported b16 head,type r cams,omni valves,springs,retainers,edilbrock victor x intake manifold,bbk throttle body. i am up for suggestions on turbo size and wut turbo to go with. i would like to make 450 to 550whp or more if possible. tell me wut you guys think
Old Jan 21, 2007 | 10:59 AM
adseguy's Avatar
Default Re: hp limits on laskey race engine? (94hatchvx)
at 500whp those engines are just going to yawn at you.
Seriously throw whatever power you want to it, but do the research on your own. You can easily look at other setups and copy away, but don't expect people to spoon feed you info for YOUR car.
Old Jan 21, 2007 | 01:26 PM
doood's Avatar
been there done that
do lots more research especially since you're considering an ls crank in a b16 block
Old Jan 21, 2007 | 03:51 PM
94hatchvx's Avatar
Default Re: hp limits on laskey race engine? (doood)
well i want to get it to at least a 1.8 liter. and i know enough about engines i was just wonderin wut you guys would do and which do you think would be cheaper. the laskey bottom end or doing up my own. why not the ls crank that would make it a 1.8?
Old Jan 21, 2007 | 04:02 PM
Semnos's Avatar
LS crank in B16...you need customs pistons
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchvx &raquo;</TD></TR><TR><TD CLASS="quote">well i want to get it to at least a 1.8 liter. and i know enough about engines i was just wonderin wut you guys would do and which do you think would be cheaper. the laskey bottom end or doing up my own.</TD></TR></TABLE>
quality work and top notch parts arent cheap. you get what you pay for in these instances.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">why not the ls crank that would make it a 1.8?</TD></TR></TABLE>
because you mentioned nothing about custom rods and pistons which would be required.
Old Jan 21, 2007 | 04:05 PM
94hatchvx's Avatar
wut would you recomend i do? im lookin for 500whp but a good strong set up.i guess while im here i should ask, is there any other shops that are good for sleeving blocks and boring the sleeves to the spec of the piston you send them?
Old Jan 21, 2007 | 04:07 PM
rmcdaniels's Avatar
The B16 block with an LS crank would require some really short rods or really short pistons, neither of which you want for 450-550 WHP if you want it to last. Use a B18C block/crank.
Old Jan 21, 2007 | 04:11 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchvx &raquo;</TD></TR><TR><TD CLASS="quote">wut would you recomend i do? im lookin for 500whp but a good strong set up.i guess while im here i should ask, is there any other shops that are good for sleeving blocks and boring the sleeves to the spec of the piston you send them?</TD></TR></TABLE>
http://www.goldeneaglemfg.com
http://www.erlperformance.com
http://www.exospeed.com
to add to the list of other places you could look at. if you want to make that kind of power send your block to anyone of those companies and see what they recommend for those power levels.
Old Jan 21, 2007 | 04:15 PM
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hatchvx &raquo;</TD></TR><TR><TD CLASS="quote">wut would you recomend i do? </TD></TR></TABLE>
Consult with a good shop with a good reputation for building strong Honda motors. Pay them a lot of $.
Either that or do a lot of searching and a lot of reading.
Old Jan 21, 2007 | 04:17 PM
94hatchvx's Avatar
Default Re: hp limits on laskey race engine? (rmcdaniels)
alright thanks
Old Jan 21, 2007 | 04:36 PM
Boostin_GSR's Avatar
If your going to buy a race motor bottom end and fork out a ton of money anyways why wouldn't you just go with a B18? More money?
Old Jan 21, 2007 | 05:00 PM
zexxbo's Avatar
Default Re: hp limits on laskey race engine? (Boostin_GSR)
benson/pauter/cp or wiseco is good for 800whp (assuming you have supporting components and a good tune)
Old Jan 21, 2007 | 05:04 PM
c-techracing's Avatar
i made 700hp but i need more so we'll see.
Knogooseness
27
Jun 4, 2013 12:07 PM
jody754
Jul 22, 2009 07:25 PM
adubaz7
Sep 20, 2007 08:31 AM
highrevnef
May 17, 2005 11:15 AM
silverb18
May 8, 2004 11:18 PM
