external tial wastegate on greddy manifold
I need to get an external wastegate so I can increase the boost more than 12 or whatever psi when I install my greddy turbo kit, but since the manifold has an internal wastegate, how would i go about changing it over to an external wastegate?
Thanks in advance
Thanks in advance
Re: external tial wastegate on greddy manifold (numbnuts22715)
The greddy kits are only rated to 10 psi.. i would recommend going with a equal-lenght manifold with an external wastegate setup.. neukin makes a great manifold and you can get the wastegate from them too... that's if you wanna go more than 12 psi
Re: external tial wastegate on greddy manifold (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood »</TD></TR><TR><TD CLASS="quote">the turbo has an internal wastegate, not the manifold. you'll need to have that welded shut. if you're going to use the greddy manifold you'll need to have a wastegate flanged welded onto it.</TD></TR></TABLE>
yeah, thats what I meant... I dunno why I said that.
but thanks, Ill see about getting that done.I only wanna boost to like 250 to the wheels or so, and I dont wanna buy a new manifold and crap to do it.
So thanks for the suggestion
Re: external tial wastegate on greddy manifold (Got_soy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Got_soy »</TD></TR><TR><TD CLASS="quote">all you need really need is a manual boost controller</TD></TR></TABLE>
would that hold though if the wastegate lets it go?
the wastegate starts to slip or whatever at 10-13 psi and I dont want to accidently blow my engine.
Re: (numbnuts22715)
dont do it. if you have the td05 kit, i wouldnt run more than 10psi. a friend of mine boosted 15lbs for about 2 monthes, not even daily but he would scramble it on the freeway before he raced. anyway, it tore the compressor to **** and he just ended up getting a new manifold and turbo so he could get the power safely. we'd both heard of others having the same or similar problems boosting 12+ psi so i just run mine at 7 psi
Re: (zeimbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zeimbo »</TD></TR><TR><TD CLASS="quote">dont do it. if you have the td05 kit, i wouldnt run more than 10psi. a friend of mine boosted 15lbs for about 2 monthes, not even daily but he would scramble it on the freeway before he raced. anyway, it tore the compressor to **** and he just ended up getting a new manifold and turbo so he could get the power safely. we'd both heard of others having the same or similar problems boosting 12+ psi so i just run mine at 7 psi</TD></TR></TABLE>
I've been runnin over 15psi on my kit for over the last 3 years on my stock block LS. 18psi is when it get's hard to hold boost steady.
https://honda-tech.com/zerothread?id=1836946
