engine management???
Old Jan 21, 2007 | 02:33 PM
UrbanAuthority's Avatar
Default engine management???
I am soon to be owning a del sol and I plan on turboing the stock D16. I'm not going for huge numbers or anything just shooting for 200-220whp. My main concern is engine management. Would I be ok with just a wideband o2 sensor and adjusting the timing or do you think i would need to go with something like megasquirt or e-manage?
Old Jan 21, 2007 | 03:01 PM
93turbo16's Avatar
Default Re: engine management??? (UrbanAuthority)
http://www.tunewithcrome.com
http://www.hrtuning.com
http://www.hondata.com
http://www.pgmfi.org
All answers lie here. You will want a chipped ecu setup and crome run various rom editing programs.
Old Jan 21, 2007 | 03:52 PM
ahhhhh, so much information lol. So let me make sure that i got this down right.
CROME utilizes you stock ecu and allows for different plugins for different applications? or is it different plugins so you can make it as expensive and safe as you want by controlling as much as possible. But, in order to run crome you have to buy products from other company so everything will work together.
I'm pretty confused if you can't tell.
wouldn't it be easier and possible cheaper just to run greddy emanage and have your stock settings as your base MAP to build off of?
If anybody can help me make more sense out of this crome setup please do lol.
Old Jan 21, 2007 | 04:18 PM
anybody??
Old Jan 21, 2007 | 04:21 PM
mtber's Avatar
Default Re: (UrbanAuthority)
Emanage would be your last choice.
A writeup I wrote kinda explains things in simple terms at http://phearable.net/tech/efibeginnerguide.html
Old Jan 21, 2007 | 04:29 PM
Boostin_GSR's Avatar
Default Re: (mtber)
I'd suggest Crome. It's a good solid tune and it's free. All you have to do is pay for the chipped ecu or if you got some skills you can chip an ecu yourself. J-K-Tunning.com was where I got mine and John is pretty reperable. Also I'm a firm believer that if your going to even think about turboing a car then you should at least do some kind of tuning to it. Tuning isn't just shoving out crazy hp numbers it's about making the turbo more compatible with your motor thus making it more reliable.
timmybilt
Appearance Build Threads
259
Jul 5, 2013 09:53 PM
Mr. Roboto
Nov 22, 2007 11:04 PM
H23A_VTEC
Apr 15, 2007 11:18 PM
fucT
Jun 23, 2004 09:57 PM
