a good ring gapping tool?
Old Jan 18, 2007 | 07:03 AM
hondaapi's Avatar
Default a good ring gapping tool?
As the topic sais.
Does somebody know a good ring gaping tool that makes this work much easier?
I donīt like the game with a file or a Dremel anymore.
A time ago I saw a ring gapping tool with a little electrical motor on one side and a dial indicator.
Does someone have pictures or a good source where I can buy it?
Thanks
Old Jan 18, 2007 | 07:23 AM
Muckman's Avatar
Moderator in Chief
Default Re: a good ring gapping tool? (hondaapi)
This is what I use. Once you get the hang of it, its easy to get square cut, consistent rings. I recommend buy an extra ring set or two in case you mess up. Or practicing on some old rings first.
http://store.summitracing.com/...w=sku
Old Jan 18, 2007 | 10:42 AM
Finland's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaapi &raquo;</TD></TR><TR><TD CLASS="quote">As the topic sais.
Thanks </TD></TR></TABLE>
I made my own.
materials list:
2 - 90 degree steel fittings with 1/4" npt threads
1 - scrap steel plate
1 - piece of 1/4-20 threaded rod for an axle
4 - 1/4-20 esna nuts
4 - flat washers
1 - 1/4-20 nut
1- cutoff wheel
1- arm off a scrap limit switch for a handle
4- scrap rubber feet
4- 8-32 self tapping screws
Drilled a couple of holes in the plate, tapped them to 1/4" npt. Opened up the port in one fitting to 1/4", drilled through the other fitting so the axle could fit through. Used the grinder to create the slot for the cutoff wheel. Also put 4 rubber feet on it so it doesn't slide around. I did all this after work in about 1/2 hour using scrap parts.
Old Jan 18, 2007 | 11:28 AM
Muckman's Avatar
Moderator in Chief
Default Re: a good ring gapping tool? (Mr. Helsinki)
Hey thats pretty sweet. Do you have any issues filing the rings square? I like the Summit one because its easy to hold the rings against the center peice and get perfectly square ring after ring.
Old Jan 18, 2007 | 11:59 AM
Finland's Avatar
Default Re: a good ring gapping tool? (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman &raquo;</TD></TR><TR><TD CLASS="quote">Hey thats pretty sweet. Do you have any issues filing the rings square? I like the Summit one because its easy to hold the rings against the center peice and get perfectly square ring after ring.</TD></TR></TABLE>
I made sure the cutting wheel was square to the plate. I also put in some screws on the surface to hold the ring (look by my thumb and you can see one)
I assume the cut was square...I don't have a measuring tool small enough to actually measure squareness on the ring end
Old Jan 18, 2007 | 12:02 PM
ExospeedAMcrx's Avatar
hehe thats coolMr. Helsinki.
Old Jan 18, 2007 | 12:03 PM
Finland's Avatar
Default Re: (exospeedAMcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exospeedAMcrx &raquo;</TD></TR><TR><TD CLASS="quote">hehe thats coolMr. Helsinki. </TD></TR></TABLE>
lol, thanks. I know it's ghetto as hell, but the price was right (0$)
imadigitalgod
Audio / Security / Video
Dec 26, 2009 10:27 PM
92civichbor
10
Aug 5, 2008 11:09 AM
MidShipCivic
Mar 17, 2005 09:33 PM
tvrsir
Dec 8, 2003 04:12 PM
hontegra
11
Oct 23, 2003 01:44 PM
