help with turbo vacuum lines
Old Jan 20, 2007 | 03:42 PM
leinadmiih00's Avatar
Default help with turbo vacuum lines
i need help running the vacuum lines for an integra with a drag turbo kit. as of right now i tapped into my IM with 1 vacuum going to the bov and 1 going to the wastegate with a manual boost controller. Theres also a fitting on my turbo housing, am i suppose to run the vacuum line from the wastegate to the turbo housing or should i run 1 vacuum line to the IM and 1 to the turbo off the wastegate?
Old Jan 20, 2007 | 03:48 PM
RedEj8's Avatar
Default Re: help with turbo vacuum lines (SickMyDuck)
You can either run the line from the turbo to the wastegate or from a vac. source to the wastegate.The side port of the wastegate to be exact, leave the top port open.
Old Jan 20, 2007 | 04:09 PM
so if im running the vacuum line from the wastegate to the vacuum source. what do i with the fitting from the turbo housing? just leave it open or do i have to close it up with something?
Old Jan 20, 2007 | 04:58 PM
RedEj8's Avatar
Default Re: (SickMyDuck)
you'll need to close it off with something.You can find a little vacuum plug at your local auto parts store that should fit.
almostjdmeg
Mar 10, 2008 01:00 PM
b18_integra
Feb 18, 2008 04:42 PM
The Dirty EJ1
Jun 10, 2007 02:31 PM
sykotic
Dec 4, 2004 09:49 AM
