What compression to run?
Old Jan 22, 2007 | 01:24 PM
hellcivic1996's Avatar
Default What compression to run?
heres my problem I already bought arias 8:1 forged pistons from summit. But i was told that having 8:5:1 would be better for my setup. I can return them if i have to, but heres my setup ls vtec with a turbonetics t3/t4 turbo and i plan on boosting 20-25 lbs of boost. Also i have precision 880cc injectors is that going to be enough. Im sending it to get sleeved and i plan on using eagle rods.
Old Jan 22, 2007 | 02:06 PM
urbansi's Avatar
Default Re: What compression to run? (hellcivic1996)
Honestly a difference of .4 CR in a setup like that isnt going to make a difference that is anywhere near noticeable.
The nice thing about having low compression like that is you are able to get away with a little more in some cases when it comes to detonation.
For the most part most people run in between 9.1-10.1 cr in a lot of boosted applications.
Like i am sure every person has been told, the tune is the deciding factor.
So in my opinion, you are completly 100% ok using those pistons.
Old Jan 22, 2007 | 02:16 PM
WS6Dreams's Avatar
Default Re: What compression to run? (urbansi)
^^^ W3RD
You'll be safer running the 8.1-1, higher compression will spool the turbo faster, but your not gonna see that with only .4 comp. points. Stick with what you have.
Old Jan 22, 2007 | 02:39 PM
Default Re: What compression to run? (WS6Dreams)
thanks guys but will my fuel injectors be big enough?
Old Jan 22, 2007 | 02:45 PM
doood's Avatar
been there done that
how much power do you want to make? that's the deciding factor in how big you go with the injectors.
Old Jan 22, 2007 | 04:04 PM
Default Re: What compression to run? (doood)
I want to make 500wph and maybe improve upon it in the future.
Old Jan 22, 2007 | 04:33 PM
snaileg's Avatar
im running cp 8:5:1 and im happy with it
Old Jan 22, 2007 | 05:58 PM
urbansi's Avatar
Default Re: (snaileg)
As far as your injectors go you should be fine, usually anything over 750cc's should support over 450whp in most cases...
ChrisYuki
Aug 16, 2015 08:19 PM
civic-r11
Mar 31, 2009 12:04 PM
Rooftop voter
Nov 2, 2008 10:01 AM
RS DC4 94
Mar 3, 2007 06:07 AM
DrPhang
Apr 30, 2002 04:12 AM
