max psi on 8.7spring tial wategate?
Old Jan 23, 2007 | 03:53 PM
lilintegra25's Avatar
Default max psi on 8.7spring tial wategate?
whats the max psi i can run on a 8.7 psi spring???
Old Jan 23, 2007 | 04:02 PM
whats the max you can run with no ebc? on an 8.7 spring?
Old Jan 23, 2007 | 04:18 PM
Default Re: (rota92)
another guy on team integra i said i cant even run 8 psi on an 8.7 spring tial 38mm wastegate.... i will be using s300 from hondata.....
Old Jan 23, 2007 | 04:41 PM
lol so what is the max i can run on this wastegate???
Old Jan 23, 2007 | 04:43 PM
Dunc's Avatar
BCICAN
Default Re: max psi on 8.7spring tial wategate? (lilintegra25)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilintegra25 &raquo;</TD></TR><TR><TD CLASS="quote">whats the max psi i can run on a 8.7 psi spring???</TD></TR></TABLE>
Without a boost controller and in a perfect world you would not be able to run more than 8.7psi of boost on your 8.7psi spring. This is obviously not a perfect world so the actual amount can and probably will vary slightly from person to person. You might run 8psi, you might run 9psi, or if you have a poorly designed manifold it might creep to 12psi or something. There is only one way to find out.....run it and see. You should be in the ballpark (within 1psi or so) if all goes well.
Old Jan 23, 2007 | 04:46 PM
Default Re: max psi on 8.7spring tial wategate? (Dunc)
all right thanks,, ill be using the spoolin log manifold
Old Jan 23, 2007 | 07:54 PM
djtrini's Avatar
I thought that whatever your wastegate spring is in PSI ie. 8.7 psi. That is the lowest boost setting you will be able to run?
Correct me if im wrong
Old Jan 23, 2007 | 08:52 PM
Dunc's Avatar
BCICAN
Default Re: (djtrini)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by djtrini &raquo;</TD></TR><TR><TD CLASS="quote">I thought that whatever your wastegate spring is in PSI ie. 8.7 psi. That is the lowest boost setting you will be able to run?
Correct me if im wrong</TD></TR></TABLE>
That is correct. Then to get more you have to add on a boost controller or some sort (either MBC or EBC).
Silvertc
Aug 29, 2008 05:10 AM
swappedcx
Jul 16, 2006 07:00 PM
95srv
May 12, 2006 07:09 AM
adictionbass
Oct 15, 2005 10:18 AM
redboost10
Nov 2, 2003 05:40 PM
