SC61 respool, who has problems
Old Jan 17, 2007 | 10:29 AM
Quickgti1.8t's Avatar
Default SC61 respool, who has problems
Either in .63 or .82 T3 flange. I'll be running minimum of 20psi daily maybe more and over 30 on race gas... Who has respool issues with this turbo, i had a 35r and didn't have any and i only reved to 7800-8000rpm... But i detroyed my 35r cause my exhaust valve broke. Im not worried about spool that much just the respool between shifts
RIP-35r lol
Old Jan 17, 2007 | 11:00 AM
j-spec_cc2's Avatar
not trying to be a smart ***, but wouldnt you be able to just buy a new turbine wheel for your 35r?
Old Jan 17, 2007 | 11:10 AM
Default Re: (j-spec_cc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by j-spec_cc2 &raquo;</TD></TR><TR><TD CLASS="quote">not trying to be a smart ***, but wouldnt you be able to just buy a new turbine wheel for your 35r?</TD></TR></TABLE>
no if it was the comp wheel then yes but for the turbine you need the whole CHRA and it is 900 bucks... Plus i sold it for 200 bucks so i dont have it anymore.
Old Jan 17, 2007 | 11:27 AM
93supercoupe's Avatar
Default Re: (Quickgti1.8t)
i was going to say the samething.
I have a 35R, brnad new if u want it. PM me
Old Jan 17, 2007 | 12:23 PM
rudebwoy's Avatar
f@#K a GT35R SC61 ftw I never had any problem with mine, quick spool even in 5th gear at low speeds, forget the GT hype get the sc61, not that I have experience with the GT's but I dont think its worth the money compare to the sc61
Old Jan 17, 2007 | 12:34 PM
komat's Avatar
Default Re: (rudebwoy)
first and 2nd gear you wont hit full boost. at least i dont unless you 3step it off the line or have longer gearing then a b16 tranny. once you get it spooled up you wont have problems getting it back to max boost on your next gear.
Old Jan 17, 2007 | 01:15 PM
Mykizism's Avatar
i have the 35e, i dont like the transient boost response.. im switching to a 35r
Old Jan 17, 2007 | 01:24 PM
firetech's Avatar
Default Re: SC61 respool, who has problems (Quickgti1.8t)
Are you going to be using any type of full throttle shift setup like what is available on most hondata, neptune etc.?
Either way, so long as you are using no larger than a 38mm wastegate with a dumptube REspool will be great with the SC61. Unless of course you are shifting below 7000 rpm.
Old Jan 17, 2007 | 01:25 PM
Default Re: (Mykizism)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism &raquo;</TD></TR><TR><TD CLASS="quote">i have the 35e, i dont like the transient boost response.. im switching to a 35r</TD></TR></TABLE>
what dont you like, my 35r spooled weird it was like nothing nothing nothing boom 25psi... If you think its going to build boost faster it wont.. Mine goes from 4psi to 25psi insanly fast.
Old Jan 17, 2007 | 01:26 PM
Default Re: (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat &raquo;</TD></TR><TR><TD CLASS="quote">first and 2nd gear you wont hit full boost. at least i dont unless you 3step it off the line or have longer gearing then a b16 tranny. once you get it spooled up you wont have problems getting it back to max boost on your next gear.</TD></TR></TABLE>
Thats werid i hit full boost is 1st and 2nd on my 35r, its a little later around 5400rpm but in 3rd gear i get full boost at 4700rpm
Old Jan 17, 2007 | 01:40 PM
Mykizism's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quickgti1.8t &raquo;</TD></TR><TR><TD CLASS="quote">
what dont you like, my 35r spooled weird it was like nothing nothing nothing boom 25psi... If you think its going to build boost faster it wont.. Mine goes from 4psi to 25psi insanly fast.</TD></TR></TABLE>
between shifts, on my 35e, it would slowly build boost back to 1.5 bar, like the gauge slowly moves.. im looking for something a lil quicker then that, hopefully my 35r will do so, with the 35e it was like vac . . . . . . . . 1.0 . . 1.5
with the 35r im hoping it will be like vac. . . . 1 . 1.5
Old Jan 17, 2007 | 01:41 PM
komat's Avatar
Thats werid i hit full boost is 1st and 2nd on my 35r, its a little later around 5400rpm but in 3rd gear i get full boost at 4700rpm</TD></TR></TABLE>
well i never had slicks so the tires just spins on 2nd
Old Jan 17, 2007 | 02:03 PM
Bailhatch's Avatar
Default Re: (komat)
well its not going to come back on boost as snappy as your 35r was but it should be pretty good if you shift pretty quick.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by firetech &raquo;</TD></TR><TR><TD CLASS="quote">
Either way, so long as you are using no larger than a 38mm wastegate with a dumptube REspool will be great with the SC61.</TD></TR></TABLE>
what? if he's not at full boost then the wastegate will be closed no matter what size it is or where the outlet goes.
Old Jan 17, 2007 | 02:11 PM
Default Re: (komat)
i dont get traction until the end of 3rd and i still get fullboost around 25psi in 1st - 4th gear...
I guess im going to get a 35r again.
Old Jan 17, 2007 | 02:21 PM
McLude2nR's Avatar
H22 SC-61 guy here. I'm happy with the respool on mine. But I've never driven a 35R car so...
Old Jan 17, 2007 | 04:58 PM
komat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quickgti1.8t &raquo;</TD></TR><TR><TD CLASS="quote">i dont get traction until the end of 3rd and i still get fullboost around 25psi in 1st - 4th gear...
I guess im going to get a 35r again.</TD></TR></TABLE>
are you launching it or just taking it easy off the line then go?
if i launch it sure i can get full boost easily
it could be my sc61 too. its not in the greatest shape. theres some shaftplay on it
Old Jan 17, 2007 | 05:01 PM
Default Re: (komat)
just rolling, no point in launch cause then it will spin worse..
Old Jan 17, 2007 | 05:04 PM
Default Re: (komat)
35r FTW!!!!
wabaki
Mar 28, 2008 04:50 AM
EK FLY
Sep 13, 2006 02:47 PM
DOHCarp
Jul 12, 2006 02:02 PM
Quickgti1.8t
Jan 4, 2006 06:04 PM
alexsracing
Aug 21, 2005 08:44 AM
