how do eagle rods get oil???
Old Jan 22, 2007 | 04:14 PM
turbo boost's Avatar
Default how do eagle rods get oil???
i got my eagle rods today for my b18a and i noticed that there is no oil hole going to the rod bearing like the stock b18a has...so how does it get oil???
Old Jan 22, 2007 | 04:21 PM
Finland's Avatar
Default Re: how do eagle rods get oil??? (snowbunny)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snowbunny &raquo;</TD></TR><TR><TD CLASS="quote">i got my eagle rods today for my b18a and i noticed that there is no oil hole going to the rod bearing like the stock b18a has...so how does it get oil???</TD></TR></TABLE>
The oil supply is from inside the crank journal. The flow of oil is from the crank up to the rod bearing. The wrist pin is lubricated by splash and by the oil squirters if you have them.
Old Jan 22, 2007 | 04:22 PM
DaveF's Avatar
from the crank
Old Jan 22, 2007 | 04:23 PM
99B16Si's Avatar
lol, whatd u think the holes in the crank were for?
Old Jan 22, 2007 | 04:25 PM
Default Re: (99B16Si)
i kinda figured oil went up threw the crank aswell but i just expected to see the lil hole like the oem rod...wasnt sure..just checking..thanks guys
Old Jan 22, 2007 | 05:57 PM
SPOOLINmatt's Avatar
Default Re: (snowbunny)
i have never noticed a hole in the rod cap???
Old Jan 22, 2007 | 06:13 PM
HiProfile's Avatar
Default Re: (SPOOLINmatt)
IIRC the stock rods have one hole on the bigger half. If piston was at TDC, its pointing ~45 degree angle upwards. My guess would be to help move oil towards the piston, but memory doesn't give me an idea of the angles where that hole and the crank hole would line up.
Old Jan 22, 2007 | 06:20 PM
99B16Si's Avatar
Default Re: (HiProfile)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HiProfile &raquo;</TD></TR><TR><TD CLASS="quote">IIRC the stock rods have one hole on the bigger half. If piston was at TDC, its pointing ~45 degree angle upwards. My guess would be to help move oil towards the piston, but memory doesn't give me an idea of the angles where that hole and the crank hole would line up.</TD></TR></TABLE>
exactly
Old Jan 22, 2007 | 09:37 PM
PrecisionH23a's Avatar
arturbo told me the oil fairy does it.
Old Jan 22, 2007 | 09:45 PM
ABK's Avatar
ABK
Default Re: how do eagle rods get oil??? (PrecisionH23a)
that hole in there is to squirt oil onto the piston. Not really needed. I would suggest getting some acl bearings (I don't think they got holes in them).
OasU
Jun 13, 2012 01:33 PM
sixtodc2
Dec 17, 2007 11:36 PM
kwik92hb
Dec 20, 2003 09:07 PM
GruvyTune
Jul 7, 2002 05:05 PM
GruvyTune
Jul 6, 2002 05:09 PM
