Breaking in motor with a turbo kit.
Its getting time to get my fresh motor in my car(84mm ls-vtec). I was wondering if it would be ok to install the turbo kit along with the new motor. The car will be started up by my tuner and partially street tunned for a/f then off to the dyno.
Does anyone have info/details for dyno break-in? How many miles? What kind of dyno?
Thanks.
Thanks.
no break in necessary..
i put my freshly fully built motor in with turbo setup and first started it on the dyno and it seen 9000rpms right away.
drove the living **** out of it since.
something different
1 Post
the few engines i've built, different break in's dont seem to have changed their end result/lifespan.
my next engine (hopefully fully built, sleeved, etc) will be broken in, driven around to get a partial throttle tune, and slowly work my way up to the way i'll drive it at its peak, all in the same session. break it in like its going to live, IMO. obviously you need to make sure everything is OK and healthy first.
Re: (redzcstandardhatch)
I agree with redzcstandardhatch, it's known that the rings seat quite quickly, but definently make sure everything is going well with the motor before you start going nuts.
I plan on just starting it up, checking for leaks, draining oil, refilling and off to the dyno
Re: Breaking in motor with a turbo kit.
ok I have to do this ... Gawwd Daaamn Honduh22!!! Talk about resurrecting the dead from over 4 years ago lolol!!! j/k
turbo*s2k
06-12-2005 12:49 PM
