Help, is my motor done!
Old Jan 18, 2007 | 08:48 PM
Civic858's Avatar
Default Help, is my motor done! *update with pics*
So I was street tuning my buddies car and BOOM, car dies and a crap load of white smoke is coming from the exhaust. We were doing a 3rd gear pull and around 7k rpm it just lost power and died. Car can't idle and when it runs it runs like crap. We ended up towing the car back to his house and found #2 and #3 spark plugs were soaking wet. There was no coolant and the oil was like coffee. It was too late to take apart the motor. We're probably not gonna work on the car til monday, any ideas what kind of damage we should be looking at.
motor:
B18C
eagle rods, 9:1 srp pistons
arp head studs
t3/t4 turbo
skunk2 mani and tb
750cc injectors
2.5 bar map sensor
crome pro
We tuned it, 14.5 psi perfectly 11-11.5:1 afr
but 20 psi, thats when it died. afr was still 11-11.5:1
using a step retard for timing
any thoughts?
Modified by SexxyTime at 10:07 AM 1/31/2007
Old Jan 18, 2007 | 08:56 PM
A.E Motoring's Avatar
Default Re: Help, is my motor done! (EJ8Coupe)
do a comp test, actually u should have done a comp and or leak down test before u made a thread, but that would be my first thing, seems like u popped a piston
Old Jan 19, 2007 | 07:41 AM
Civic858's Avatar
it was late and freezing plus we were tired (waiting for tow truck), my friend is fearing the worst - cracked sleeve.
Old Jan 19, 2007 | 07:43 AM
DaveF's Avatar
just get to work on the damn thing. this wont be the 1st time, and certainly wont be the last.
Old Jan 19, 2007 | 09:57 AM
93turbo16's Avatar
Default Re: Help, is my motor done! (dturbocivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dturbocivic &raquo;</TD></TR><TR><TD CLASS="quote">just get to work on the damn thing. this wont be the 1st time, and certainly wont be the last.</TD></TR></TABLE>
haha, its always like that.
But I would bet cracked sleeve.
Old Jan 22, 2007 | 08:28 AM
Civic858's Avatar
Just took of the head and....cracked the #2 sleeve, big time. Can the motor be salvaged? Any advice on what to do next?
Old Jan 22, 2007 | 10:52 AM
mike1114's Avatar
Sounds just like my car during 5th gear pull after dyno tune, during the partial throttle street tune.
Cracked sleeve for sure.
Old Jan 22, 2007 | 11:10 AM
morgan@synapse motorsport's Avatar
get some pics up, it might be salvagable if u send it out to get sleeved.
Old Jan 22, 2007 | 11:19 AM
adseguy's Avatar
I bet a sleeve blew if you have coolant. I've been in a car when it happened....kinda scary .
Pop that head open and see for yourself since you are going to have to anyway.
20psi on what turbo? What kinda gas? pics of the map? Lost fuel pressure?
usually 20psi putting down a lot of power and shouldn't be tuned on the street until after a dyno run and only done for real-life AF adjustments
edit: Opps, I didnt read I guess you did crack a sleeve. Any pics of the piston? We can tell you if it was det. or power that did it
Old Jan 31, 2007 | 09:12 AM
Civic858's Avatar
Default Re: Help, is my motor done! *update with pics* (SexxyTime)
Well, we tore down the block to send it to AEBS and get some sleeves...
#2 sleeve cracked
#2 bearings toasted
Now new bearings are needed, do I have to replace all the bearings or just #2
bearings? All the other ones look fine. And does the crank need to be fixed?
Modified by SexxyTime at 10:23 AM 1/31/2007
Old Jan 31, 2007 | 12:04 PM
Tuesday Club's Avatar
go to a machine shop....w/ the pistons and crank etc.
ALWAYS replace the bearings (all) anytime you have a problem...just in case.
Old Jan 31, 2007 | 12:14 PM
drintegra's Avatar
can you post the bin??
Old Jan 31, 2007 | 12:25 PM
blackeg's Avatar
Default Re: Help, is my motor done! *update with pics* (drintegra)
thats the EXACT same thing that happend to me, cracked sleeve and all...
E85B18
Jul 9, 2021 12:38 AM
flangemastermike
Nov 15, 2008 08:00 PM
advert
Mar 18, 2007 08:23 PM
crazyitr
Nov 11, 2003 08:17 PM
PM-Performance
Aug 8, 2003 05:49 AM
