clocking the turbo
Old Jan 18, 2007 | 07:33 AM
Drkaccrd's Avatar
Default clocking the turbo
Do yall think I can clock the turbo downwards without removing the turbo & manifold from the block?
Old Jan 18, 2007 | 07:45 AM
Schister66's Avatar
Man U FTW
Obviously there is limited space to clock the turbo downward, but my main concern, even if you could do it, is how would you run the charge piping??
Old Jan 18, 2007 | 08:12 AM
Drkaccrd's Avatar
Default Re: (Schister66)
I would run it underneath. I already have an intercooler to accomodate. I just want more under the hood in case anthing needs to be replaced in the near future...ie starter, alterantor, a/c compressor etc..........
Old Jan 18, 2007 | 09:47 AM
Drkaccrd's Avatar
Default Re: (Drkaccrd)
TTT for an answer
Old Jan 18, 2007 | 01:28 PM
Drkaccrd's Avatar
ttt
Old Jan 18, 2007 | 01:45 PM
gritsak's Avatar
This isnt a technical question so i dont know why you are waiting for an answer. Assuming you can get to all the bolts and loosen them, just look and see if there is enough room to turn it. Taking off the fan would allow for more room if you turned the outlet towards the front of the car, and would be much easier than removing the turbo/manifold.
Old Jan 18, 2007 | 01:59 PM
fmfkid250's Avatar
spin your turbo around
Old Jan 18, 2007 | 02:26 PM
Muckman's Avatar
Moderator in Chief
If there isnt enough room to rotate the compressor housing you can just take all the bolts out, remove the cover and reinstall it in whatever position you want.
Old Jan 18, 2007 | 05:47 PM
HiProfile's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drkaccrd &raquo;</TD></TR><TR><TD CLASS="quote">TTT for an answer</TD></TR></TABLE>
I'll say yes, you can. Mainly because I'm staring at a picture, and you have the car outside your house.
You seem to have your mind made up due to the 2nd IC, so I'm curious why you didn't give it a shot already? Its 6 bolts one way, or 4+4 bolts & 2 lines another.
Old Jan 19, 2007 | 05:06 AM
Drkaccrd's Avatar
Default Re: (HiProfile)
i was checking cause my cousin said there was bolt on the turbine side he thought....... he said he hadnt done that in a while so he said he coudlt remember. But yall pretty much answered my question thanks
95whitegizzer
Jun 28, 2006 05:21 PM
tolowhb
Apr 18, 2004 07:05 PM
OKSolSi
May 5, 2002 07:34 PM
MiraiZ
May 3, 2002 08:38 AM
pagong
Jul 17, 2001 07:38 PM
