What air filter to use on an fi setup??
Old Jan 19, 2007 | 03:32 PM
rdeezy78's Avatar
Default What air filter to use on an fi setup??
I just sent my block out to GE and I plan on running about 20lbs. The air filter I have now is a no big name brand. I read alot about air filters collapsing and I don't want that to happen to me. Does anyone know which air filters(cone prefferably) can handle that task of my boosting needs? I already searched and just got a thread about sone akimoto filters from 5/26/06. Are the aem dry flow filters a good choice? I need a 2.75 opening and about a 5 inch or so element to fit my setup. Any helpful suggestions will be greatly appreciated.
Old Jan 19, 2007 | 03:39 PM
Topdawgg's Avatar
K&N makes all kinds of good quality filters for any application
Old Jan 19, 2007 | 03:45 PM
rdeezy78's Avatar
Default Re: (Topdawgg)
Yeah I seen a neat looking conical filter by k-n with the top center open with another element in the center. Would that be a good filter for a fi setup? Do you know if it lets more air in since it has the extra element?
Old Jan 19, 2007 | 03:47 PM
TurbodTegSfaria's Avatar
Default Re: (rdeezy78)
my intake fell off last night on a bumpy road, i ran over it once, then backed up and ran it over again....its completely pancaked,damn
Old Jan 19, 2007 | 03:48 PM
rdeezy78's Avatar
Default Re: (TurbodTegSfaria)
that sucks. What kind was it?
Old Jan 19, 2007 | 04:53 PM
RedEj8's Avatar
How about the apexi filter?
Old Jan 19, 2007 | 05:03 PM
Benjithx's Avatar
Default Re: (RedEj8)
buy a few different ones and try them on the dyno. I picked up 15 hp at 17psi by changing my filter
Old Jan 19, 2007 | 05:18 PM
rdeezy78's Avatar
Default Re: (Benjithx)
Help would be telling me which filter you got more hp from. Good filters are not cheap. I would appreciate it?
Old Jan 19, 2007 | 07:11 PM
N20civicB18's Avatar
Default Re: What air filter to use on an fi setup?? (rdeezy78)
K&N or none
Old Jan 19, 2007 | 07:17 PM
Mr HYDE's Avatar
Default Re: What air filter to use on an fi setup?? (N20civicB18)
i run a 4inch k&n, wont you anything else. F those foam ones they get sucked in the turbos
Old Jan 19, 2007 | 08:54 PM
PrecisionH23a's Avatar
Custom K&N... just go to anywhere that stock them and start looking through the catalog for dimensions.
Old Jan 19, 2007 | 09:29 PM
vtec.dc2's Avatar
kn is the only company i know of offering a variety of custom filters and quality filters.. get the largest you can fit. they have many sizes to choose from
Old Jan 19, 2007 | 09:34 PM
iBrandon's Avatar
Default Re: What air filter to use on an fi setup?? (vtec.dc2)
Apexi!
Old Jan 19, 2007 | 09:54 PM
vladd's Avatar
what about those of you that don't have room for a filter? does anyone sell a cap-like filter? i looked on k&n's web site and didn't see anything like that. i'd rather buy a pre-made one than ghetto rig my own up.
Old Jan 20, 2007 | 12:18 AM
IceySC's Avatar
i just got the apexi i head alot of good things about it.
Old Jan 21, 2007 | 05:50 PM
rdeezy78's Avatar
Default Re: What air filter to use on an fi setup?? (PrecisionH23a)
what about the dry aem filters?
Old Jan 21, 2007 | 06:03 PM
doood's Avatar
been there done that
http://www.knfilters.com/search/universal.aspx
start searching
sundownz's Avatar
Default Re: What air filter to use on an fi setup?? (Mr HYDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr HYDE &raquo;</TD></TR><TR><TD CLASS="quote">i run a 4inch k&n, wont you anything else. F those foam ones they get sucked in the turbos</TD></TR></TABLE>
Seriously? Is this true for the Greddy foam filter that comes with their turbo kits? Seems like it would be darn near impossible for it to become dislodged.
Old Jan 21, 2007 | 06:26 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: What air filter to use on an fi setup?? (sundownz)
i dont run a filter at all on my turbonetics, since it wont clear my stock fan. Is it bad to run no filter?? What size kn will fit??
Old Jan 21, 2007 | 06:40 PM
cuin9sec
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Topdawgg &raquo;</TD></TR><TR><TD CLASS="quote">K&N makes all kinds of good quality filters for any application</TD></TR></TABLE>
very good choice.
Old Jan 21, 2007 | 06:50 PM
blinx9900's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Benjithx &raquo;</TD></TR><TR><TD CLASS="quote">buy a few different ones and try them on the dyno. I picked up 15 hp at 17psi by changing my filter</TD></TR></TABLE>
which filter did you end up using?
Old Jan 21, 2007 | 06:53 PM
Pnoyej6's Avatar
* B A N N E D *
Default Re: (blinx9900)
im trying to fine a very slim kn filter since im running no filter right now on my turbo
Old Jan 23, 2007 | 12:53 PM
Soccerking3000's Avatar
Default Re: (nWilk666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nWilk666 &raquo;</TD></TR><TR><TD CLASS="quote">the metal mesh from a noodle strainer. its pretty tough material. i got one from walmart works like a champ.
[IMG][/IMG]</TD></TR></TABLE>
worst idea ever
1-it cuts the surface area of the inlet down significantly
2- it sucks at filtering anything
Old Jan 23, 2007 | 02:02 PM
CRX T-Si's Avatar
Default Re: (Soccerking3000)
K&N, just goto one of the performance stores that stock K&N and ask the guy what they have that will fit and test fit that **** till you got the perfect one.
When I got mine, I told the guy that I need a 3" inlet about 5-7" in length and boom he got it for it and it worked perfectly.
No Foam Crappy stuff, would never recommend that ****.
kirlous k
Jun 23, 2018 09:34 AM
blue_hatch
Mar 17, 2005 11:08 PM
traumatized
May 31, 2004 10:40 AM
Brian-Brian
Jun 5, 2003 09:35 AM
ceemarun
May 25, 2002 03:24 AM
