Removing Cat, need to re-tune?
Old Jan 17, 2007 | 07:43 AM
IntegraMastaz's Avatar
Default Removing Cat, need to re-tune?
Hi all,
Setup is a B18B, Garrett T3 10Psi, 232Whp on a mustang dyno.
I got a 2.5'' Dp to a 3'' high flow magnaflow Cat, to a 3'' exhaust. People keep saying to remove the Cat for faster spool.
My question is: if turbo spool faster, it will need more gaz at that time so I will need to get the car to the dyno again... I am right?
Thank you for any input related.
Old Jan 17, 2007 | 07:49 AM
u2civic1's Avatar
Default Re: Removing Cat, need to re-tune? (IntegraMastaz)
yes
Old Jan 17, 2007 | 08:50 AM
aaroboost's Avatar
meh, i dunno. personally i would have thought you would be fine since your cat is a high flow and i wouldnt think it would make much difference.
Old Jan 17, 2007 | 09:22 AM
u2civic1's Avatar
Default Re: Removing Cat, need to re-tune? (u2civic1)
if it doesn't really make a difference then you don't really have to remove the cat.
but if you remove it and it spools or makes more power i would retune it.
Old Jan 17, 2007 | 12:58 PM
doood's Avatar
been there done that
increasing the efficiency of the engine, whether it be inhaling or exhaling, would be best accompanied with a tune.
Old Jan 17, 2007 | 01:03 PM
Fo-Do Fanatic's Avatar
Default Re: Removing Cat, need to re-tune? (doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doood &raquo;</TD></TR><TR><TD CLASS="quote">increasing the efficiency of the engine, whether it be inhaling or exhaling, would be best accompanied with a tune.</TD></TR></TABLE>
very true. i would retune it period. anything more you put on your car or take off is going to affect your AF ratioo. a good 30 min tune should be just fine.
Old Jan 17, 2007 | 03:19 PM
Thx for your input
Old Jan 18, 2007 | 07:08 AM
631 Teggy's Avatar
Default Re: (IntegraMastaz)
More air out = more air in. Retune to be safe, or borrow a wideband and see how much it changed.
D-meet07
Aug 11, 2006 08:36 AM
teg969
Aug 31, 2004 06:04 PM
speedyracer_25
May 31, 2004 05:00 PM
UA6 BALLER STATUS
Aug 20, 2003 11:23 PM
Suzukablue
Jul 28, 2003 09:10 AM
