gt35R OR full-race GT3567R
I am currently finishing my build and I am just getting ready to order my full-race top mount turbo manifold I wanna see between 550hp and mid 600hp. My queastion is which would be a better turbo between the 2 if at all and would I go with a t3 flange or t4 flange..I will give you the run down of my setup
GSR Head ferrea valves Jg-engine dynamics valve springs (ORANGE)
titanium retainers
minnor port work
GSR CAMS (soon turbo cams)
Skunk 2 pros series cam gears
EDLEBROCK manifold
S2000 TB
84.5mm darton mid sleeved block
Wiseco pistons 8:8:1 compression
Eagle H-Beam Rods
stock GSR crank
ARP Main studs
ARP rod bolts
ARP Head studs
GE oil squirter plugs
New OEM Type r Oil pump ( possible getting pro drive gear)
moroso oil pan slightly bigger than stock
GSR Transmission
11lb flywheel
Quaife LSD
ACT XTREAM pressure 6 puck unsprung Disc ( will be getting a Twin disc clutch)
The setup is in a 94 civic coupe and the car is equiped with a 8 point chromoly cage on 24.5x8x13 bogart wheels and 24.5x9x13 mt slicks
any suggestions on a good turbo would be appreciated
JOSH
titanium retainers
minnor port work
EDLEBROCK manifold
S2000 TB
Eagle H-Beam Rods
stock GSR crank
ARP Main studs
ARP rod bolts
ARP Head studs
GSR Transmission
11lb flywheel
Quaife LSD
JOSH
you can run a 35r on a ramhorn but it needs to be made for the correct exhaust hosuing your running...The gt housing flares to 3 inch and does not fit well on our cars. you can get the 2.5 inch 4 bolt or the 5 bolt for an easier fit
Re: (rota92)
[QUOTE=rota92]
I have the only one to my knowledge on a D-series lol But that probly wont help ya much!
How much boost are you running with that gt3567r? Whats the lowest psi you can run on it, did you notice a big difference switching from you gt35r to gt3567r
Re: (JLHDOHC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JLHDOHC »</TD></TR><TR><TD CLASS="quote">How much boost are you running with that gt3567r? Whats the lowest psi you can run on it, did you notice a big difference switching from you gt35r to gt3567r </TD></TR></TABLE>
You could run 1psi if you had a wastegate that had a 1psi spring.
Re: (JLHDOHC)
If your looking for 550-600 go with a t3 based 35r with a .82 a/r, it will give you a good power band and will meet your goals.
Here is a dyno graph of a 84mm gsr with a 35r .82 .a/r at 26 psi.
Re: (Synapse Motorsport)
thats pretty exciting to see...The only reason why I was looking at the 3567r was because I was going to get the t3t67 but such a slow spool from what I heared thats awsome on what you did with that setup How does it do on low boost is that turbo on a top mount manifold or ram horn.....
Re: (HKSuperSi)
Here is a car we used the Full-Race GT3567R!
Mods: Slowmotion Built B18C1 Longblock, 1000cc Injectors, Full-Race Intake Manifold, Hondata S300, SloMo Stage 4 Turbo Kit including GT3567R, a 4" DP and 3" IC Piping, Stock Cams and Cam Gears, BDL 70mm TB, Walboro 255HP Fuel Pump and Stock Fuel Lines
With Cam Gear Adjustments I'm sure I could see 625hp at the same Boost Levels.
Customer Hopes to do Cams, Cam Gears, and Fuel system and see 700whp some day!! Shouldn't be a problem with about 30-32psi.
Joshua
SlowMotion Motorsports
Joshua
Re: (pbsracerx)
Are you pretty happy with the turbo setup is the block sleeved what bore kinda was hoping for a little more tq than that on my setup..........is it worth going gt3567r over the gt35r
Re: (Blind-Fashion)
[QUOTE=Blind-Fashion]637whp on a GT35R with .82 exhaust housing @ 26 psi
If you dont mind me asking whats your setup I think I watch your car over in battle of the imports last year in kent....
simplsi
Mid-Atlantic (Sales)
12
08-24-2008 11:09 PM
