queston on hondata s200
Old Jan 17, 2007 | 05:33 PM
bigbadboy's Avatar
Default queston on hondata s200
are you able to use a map switch with this system?? if not which system can you use it with
Old Jan 18, 2007 | 12:46 PM
bigbadboy's Avatar
bump
Old Jan 18, 2007 | 01:28 PM
doood's Avatar
been there done that
Default Re: (bigbadboy)
meaning switch between two different maps for hi/low boost? you can probably burn one map onto a chip and another on another chip then switch them out.
with neptune you can have two maps made and switch between them with the flip of a switch.
Old Jan 18, 2007 | 01:44 PM
93turbo16's Avatar
Default Re: (doood)
There is also a part called a two timer. And you use a chip with 512 memory, and burn the first map in the 1-256 memory and the other map on the higher part of the memory. You just have to edit the adress that the chip burner actually burns in the chip.
http://www.moates.net has the 2timer. That is the thing you can use to switch maps with.
But as far as internal, Neptune has dual map capability.
Old Jan 18, 2007 | 04:02 PM
Pro-Am 1934's Avatar
Default Re: (93turbo16)
Also, if your tuner has the latest ROM Editor (version 4) you can set up the secondary maps to do that for you as well. You can set the parameters for that, and when they are meet, you will kick on to those maps. You can activate them through one of the 2 nitrous activation set points.
Jason
Old Jan 18, 2007 | 04:25 PM
bigbadboy's Avatar
yea i want to be able to switch between to different maps cause i want to get my car fully tuned on e85 and on 93 octane.
nytosc
Engine Management and Tuning
10
Aug 18, 2011 09:58 AM
josh0407
Aug 22, 2007 10:47 AM
sneakypete
Feb 18, 2004 10:24 AM
dariusz
Nov 27, 2002 03:38 PM
