What spark plugs to use on turbo H22
Re: What spark plugs to use on turbo H22 (x-1)
Depends on how much boost you are running, compression ratio, etc.
Generally I like to start with 7 series for lower boost, read the plugs and check the color change on the strap and if needed go colder.
Usually start with a gap of .035 and work my way down from there if needed.
You could have called me and ask me that questions, I got those NGK's 7 series cold plugs if you need them. I'll see you tomorrow, I'll stop by for that Integra.
Re: What spark plugs to use on turbo H22 (b16hybridsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol »</TD></TR><TR><TD CLASS="quote">ngk bkr7e's here</TD></TR></TABLE>
x2
x2
Use the NGK 9s.U can get them at Camp 1320 in Chatsworth,California.Around 15.00.They work good in mine.Set the gp at 25mm.If your running 10psi,They should last a few months.If more like 20psi,Then change them twice a month.
