ahhh help?!
Old Jan 22, 2007 | 12:27 AM
Carbcivic's Avatar
Default ahhh help?!
ok... i just put a turbo setup on my car , im having a problem with it right now lol... if i start out in 1st gear and flatten it , it works great, but if i go from 2nd gear and flatten it i get turbo spikes, but once after about.. 5700 rpm and up the turbo works great with no spikes... now once i get into 3rd gear.. i get spikes like crazy! and all of a sudden the check engine light goes on but not sure what sensor went i just usually turn the car off and turn it back on and its gone.. any help?!
Old Jan 22, 2007 | 12:55 AM
morgan@synapse motorsport's Avatar
Default Re: ahhh help?! (Carbcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Carbcivic &raquo;</TD></TR><TR><TD CLASS="quote">ok... i just put a turbo setup on my car , im having a problem with it right now lol... if i start out in 1st gear and flatten it , it works great, but if i go from 2nd gear and flatten it i get turbo spikes, but once after about.. 5700 rpm and up the turbo works great with no spikes... now once i get into 3rd gear.. i get spikes like crazy! and all of a sudden the check engine light goes on but not sure what sensor went i just usually turn the car off and turn it back on and its gone.. any help?!</TD></TR></TABLE>
a little more information would help, what car what engine what turbo what other parts are u running pretty much a run down. and most importantly how was the car tuned for the turbo setup
Old Jan 22, 2007 | 01:06 AM
Carbcivic's Avatar
Default Re: ahhh help?! (hybrdthry911)
haha sry.. ya it would help... b16 bottom end with gsr head, t3 turbo, manual boost controller, i also put in a 5 psi spring for now, aem fuel rail... never touched the timing or anything.. , also have a safc, the car runs rich when u flatten it.. also got the the ngk spark plugs part number - BKR6E-11 car wasnt really tuned for the turbo as of yet.. what would fix it?? any help plz?
Old Jan 22, 2007 | 05:00 AM
DaveF's Avatar
stop beating on your car before you blow the engine up. you are most likely getting a CEL because your map sensor is seeing boost(which they dont like from the factory)
you are getting boost spike because your wg cant keep up with the exh flow. either that or you have a tiny *** turbo, and the boost just falls off up top....and spikes down low because its tiny....
Old Jan 22, 2007 | 09:33 AM
Carbcivic's Avatar
Default Re: ahhh help?! (dturbocivic)
okay.. well it worked great at one point when i had the boost controller on... i just put that back on and it almost runs good but .. some spikes yet.. if u dont flatten it and just push the throttle in like quarter throttle and let the turbo spool than there are no spikes at all.. only get spikes when u hold it flat
Modified by Carbcivic at 3:19 PM 1/22/2007
Old Jan 22, 2007 | 10:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Carbcivic &raquo;</TD></TR><TR><TD CLASS="quote">okay.. well it worked great at one point when i had the boost controller on... i just put that back on and it almost runs good but .. some spikes yet.. if u dont flatten it and just push the throttle in like quarter throttle and let the turbo spool than there are no spikes at all.. only get spikes when u hold it flat </TD></TR></TABLE>
get it tuned or i garantee you the spikes will be the least of your concerns
Old Jan 22, 2007 | 11:20 AM
Carbcivic's Avatar
anyone know any good tuning places in pa??
Old Jan 22, 2007 | 11:26 AM
you're going to need to get some sort of engine management system not a fuel control unit. cant half tune a car
Old Jan 22, 2007 | 11:29 AM
mike1114's Avatar
damn, I hate to post this but does anyone ever search anymore?
can't anyone read the FAQ at the top of the page that says READ HERE BEFORE YOU START ASKING STUPID REPEAT QUESTIONS??????
I hate HATER-TECH anymore...this site sucks. Bunch of kids with no knowledge asking the same questions over and over and over and over and over.....its like 1 time a month something good is on here.
sorry, just venting. I'd like to read some actual "tech" for a change instead of what whp do you think I'll get? or this crap.
Modified by mike1114 at 8:56 PM 1/22/2007
Old Jan 22, 2007 | 01:58 PM
coneheadsracing's Avatar
Default Re: ahhh help?! (mike1114)
Make sure you hooked the boost controller up right. The one i have, if you hook the lines up backwards (done this) it will spike, drop and do all kinds of crazy *** ****.
Oh, and get it tuned, hell its cheaper to chip it, throw in a shitty basemap, then your safc, and a hell of a lot safer.
Old Jan 22, 2007 | 03:00 PM
sc4dr's Avatar
Default Re: ahhh help?! (coneheadsracing)
Atleast new people are getting into the sport. If there werent stupid ?'s everyone would know everything, and there would be nothing to talk about.
Old Jan 22, 2007 | 03:08 PM
DaveF's Avatar
Default Re: ahhh help?! (sc4dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sc4dr &raquo;</TD></TR><TR><TD CLASS="quote">Atleast new people are getting into the sport. If there werent stupid ?'s everyone would know everything, and there would be nothing to talk about.</TD></TR></TABLE>
we all started somewhere, i know i didnt know everything there was to know back then, and i still dont know it all to this day.. everyday i learn something new.
808k20z3
Honda Civic (2006 - 2015)
Jan 21, 2007 10:55 AM
TurboTagTeam
Oct 18, 2004 09:01 AM
thastaniard
Jul 20, 2004 10:42 AM
slammeddelsol95
18
Jul 19, 2004 01:44 PM
