turbo timer and EBC needed for turbo install???
Old Jan 19, 2007 | 05:16 PM
lilintegra25's Avatar
Default turbo timer and EBC needed for turbo install???
im am going to be turboing my 98 ls in about to weeks,,,,, i use my truck as a daily driver so mostly just drivin the integra on weekends ,,, i have all of the parts ,, etc. im going to be using hondata s300,,, i know what the EBC and the turbo timer do, but is this nessacry???
Old Jan 19, 2007 | 05:21 PM
iheartintegras's Avatar
No
Old Jan 19, 2007 | 05:26 PM
rdeezy78's Avatar
Default Re: turbo timer and EBC needed for turbo install??? (lilintegra25)
You definitely need the turbo timer. The boost controller is not necessary unless you want to run more boost than what the spring in the wastegate or actuator is set to. Good luck.
Old Jan 19, 2007 | 05:44 PM
Boner_Ben's Avatar
Default Re: turbo timer and EBC needed for turbo install??? (rdeezy78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rdeezy78 &raquo;</TD></TR><TR><TD CLASS="quote">You definitely need the turbo timer. The boost controller is not necessary unless you want to run more boost than what the spring in the wastegate or actuator is set to. Good luck. </TD></TR></TABLE>
What the hell do you need one of those for? Save your money.
Old Jan 19, 2007 | 05:56 PM
Treblarefils's Avatar
Default Re: turbo timer and EBC needed for turbo install??? (Boner_Ben)
Agreed Dont have a turbo timer.. never have.. dont care if i ever do either.....just let it idle a bit after youve been beating it before shutting the car off.....Spend your saved money on a nice wideband setup not needed but very nice item to have.
Revlon Charly
Mar 14, 2007 09:37 PM
solingermany
Jun 19, 2006 07:16 AM
CivicRaping
Apr 14, 2005 08:40 PM
brasilstreet
Jun 16, 2004 02:21 PM
smallttocs
Feb 22, 2003 09:47 AM
