turbo ls headwork
Old Jan 19, 2007 | 03:34 PM
t3b18b's Avatar
Default turbo ls headwork
since ls motors naturally fall off after 5000 rpms or so. what would the first steps be to help breathing capabillities without drastically altering geometry, ildling, and other things? could you get a port and polish and use stock cam, etc.? havent come across much info on this. any insight is appreciated
Old Jan 19, 2007 | 03:49 PM
highmilehatch's Avatar
Default Re: turbo ls headwork (t3b18b)
Take a look at this dyno graph:
http://forums.evans-tuning.com...=402t
I'd call that a dramatic difference in breathing capabilities. Take note of the parts used.
Old Jan 19, 2007 | 05:02 PM
Benjithx's Avatar
Default Re: turbo ls headwork (highmilehatch)
Search search search. there are plenty of high HP LS mills out there
Old Jan 22, 2007 | 08:50 PM
snaileg's Avatar
ls heads dont fall off at 5000k... they drop off after about 7200k if you want to be able to rev higher to about 9k i would go with a good set of turbo cams and at least do a mild p&p to the head because after i did that with my setup after 7200k it just went up and didnt drop off until about 9k but the power went up and stayed steady and also upgrade your springs and retainers i will try and scan my dyno graph and post it up for you
Ls91sI
Sep 28, 2005 12:51 PM
T S R Performance
Mar 25, 2004 07:08 PM
speedy108
Jan 13, 2003 11:44 PM
dragsol
Aug 31, 2002 10:41 PM
skellator_thoj
May 17, 2002 10:30 AM
