will this work for an oil pan fitting ? (pic)
Old Jan 10, 2002 | 04:03 PM
D-SPEED's Avatar
Default will this work for an oil pan fitting ? (pic)
the fitting is a "3/4'' female hose to 1/2'' MIP adapter"
-the fittings i have seen others use (such as dustin on his site) have a cone shaped fitting on the 1/2'' threaded part...I'm pretty sure that helps seal in the AN hose fitting. Would this be a problem ?
also, im not even sure this is the correct threading...i dont know much about pipe threads. It threads into another piece that i know is a 1/2'' NPT, but at the end, it gets tight and stops moving like it is the wrong threading. I dont know, but ive heard NPT threading is supposed to do this.
I couldnt find anything at Home Depot or at hardware stores that looked like what others have used...will this work or should i go look harder
Old Jan 10, 2002 | 04:14 PM
b18bvudoo's Avatar
New User
Default Re: will this work for an oil pan fitting ? (D-SPEED)
as long as the 1/2" npt will screw in its fine. i got my oil pan fitting from home depot after i lost my earl's weld fitting and everything worked out ok. i didnt weld the oil pan fitting tho; used jb weld instead and no oil leaks yet, altho its only been a couple of days since i installed the turbo. use teflon tape to make it even more snug.
Old Jan 10, 2002 | 04:16 PM
JM Performance's Avatar
Default Re: will this work for an oil pan fitting ? (vudoo666)
I had a 5/8" barb/pipe fitting. I tapped the pan to 5/8". screwed it in, the JB welded the hell out of it on both sides. One month so far and its perfect.
Old Jan 10, 2002 | 04:42 PM
D-SPEED's Avatar
Default Re: will this work for an oil pan fitting ? (00SilverLS)
-what is a barb fitting ?
-what is an earls weld fitting ?
Old Jan 10, 2002 | 05:02 PM
AlphaKennyWun's Avatar
I had jb weld on my pan and it started to have a slow leak after 6 months. I drained the oil....removed the 16 nuts from the pan and took the pan to a machine shop. It cost me like $30 and i reused the same oil pan gasket. I have had no leaks in several years.
Old Jan 10, 2002 | 05:11 PM
D-SPEED's Avatar
Default Re: will this work for an oil pan fitting ? (SO3Burner)
also.....is the oil pan steel or aluminum ?
Old Jan 10, 2002 | 07:38 PM
b18bvudoo's Avatar
New User
steel
Old Jan 10, 2002 | 08:30 PM
D-SPEED's Avatar
what is this "earls weld fitting ? "
i found the "weld fitting" on anplumbing.com .... but there is no picture.
[Modified by D-SPEED, 5:58 AM 1/11/2002]
Old Jan 10, 2002 | 10:15 PM
degradated's Avatar
New User
the biggest problem i see with this besides the fact that it might be the wrong thread pitch is that the fitting shown above is brass.
I originally had a brass fitting welded into my pan, and the thing leaked like a son of a bitch. 1/2 quart of oil would be present on the garage floor each morning.
So I ended up having to buy a new pan ($120), and went back to Home Depot and looked a little harder to find a 1/2 PT STEEL fitting.
Brought it to a more reputable shop and had it welded. I haven't had a drop of oil leak since.
You see, not all welders are able to weld brass. I believe it requires a higher temperature, so pan warpage might result, which is why I think mine leaked (pan was warped around the area, and the fitting was slightly oblong so it didn't have a tight seal - even teflon tape wasn't enough)...
hth
Old Jan 10, 2002 | 11:52 PM
D-SPEED's Avatar
Default Re: will this work for an oil pan fitting ? (degradated)
yeah that was another concern i had. I was told that brass and steel can be "brazed" together, but it takes a more skilled welder to do this, because the two materials have different melting points and it is harder to get them together without frying one...thats just what i heard, but i assumed that since everybody else used brass fittings it would be OK.
I think i will go look for a steel fitting.
anybody know what an earls weld fitting is ?
Old Jan 11, 2002 | 08:28 AM
TurboSedan's Avatar
New User
Yep, just ditch the brass one and get a steel weld fitting. It is a cheap part, I got mine for like $6.
Old Jan 11, 2002 | 12:41 PM
D-SPEED's Avatar
Default Re: will this work for an oil pan fitting ? (97CivicFerio)
i went to two home depots today looking for steel fittings....the closest i found was a short "nipple" pipe with 1/2'' threading on it...i thought maybe i could weld that onto the pan, but decided against it.
-anybody have ideas where to look ?
-what about this "earls weld fitting" ?
Old Jan 11, 2002 | 12:54 PM
TurboSedan's Avatar
New User
What you want is Summit Racing Part number EAR-997110. Go to http://www.summitracing.com and enter that part number in the Summit Part Number Search. It is -10AN which is 5/8". There is no male 1/2" steel weld fitting. You'll need a -10AN female fitting to attach to the weld fitting if you do not already have one.
Old Jan 11, 2002 | 01:01 PM
dustin's Avatar
Use one of these:
http://www.bakerprecision.com/adapt13.htm
AN Thread Male Union - AN 815 961510 10
I cut one side of it off, and had someone braze it to my oil pan:
http://imglib.************/index.cgi?...ewimage&id=689
Dustin
D15Bbigred
Mar 1, 2007 07:36 PM
Fatty_1775
Jul 30, 2006 08:04 PM
the.hamburglar
Jul 16, 2005 08:34 AM
CATCH DIS HATCH
Apr 14, 2004 08:50 PM
minivan81
Aug 20, 2003 02:12 PM
