Boost levels
Old Jan 9, 2002 | 04:17 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Boost levels
What would i be able to run with 9.0:1 compression stock bore pistons, Eagle rods, and ARP rod bolts? Rest of the motor will be basically stock besides a ported and polished head and a ported intake manifold. I was thinking of using a t04e but im not sure...i might try to run a bigger turbo with standalone and larger injectors...
Old Jan 9, 2002 | 04:34 AM
TurboSedan's Avatar
New User
Default Re: Boost levels (Big Carbon)
Do a search
Old Jan 9, 2002 | 05:55 AM
ekb18c's Avatar
sounds good to me
Old Jan 9, 2002 | 06:51 AM
Seraph0's Avatar
~15psi but it depends on soooo many things
Old Jan 9, 2002 | 11:06 AM
synergy004's Avatar
Default Re: Boost levels (MarkC)
True dat, i am runnin Je 9.0:1 pistons and eagle rods with the arp rod bolts that comes with it. You better get a fuel managment device<<< All depends on your fuel set up and tuning.
g luck
blackccoupe
Sep 26, 2009 01:24 PM
n.e.coupe
Sep 15, 2005 08:10 AM
RACEPAK
Aug 21, 2005 09:09 AM
boostedsol
Mar 23, 2003 07:20 PM
dohc_Cx
Nov 25, 2001 02:40 AM
