How do you bypass the IAC...???
Old Jan 11, 2002 | 07:01 PM
GSRwBOOST's Avatar
Default How do you bypass the IAC...???
i tapped on that damn thing tonight with a wrench.. and the car idled better... i tink the valve is stuck or the coolant lines ARE on backwards... the valve must be stuck or something.. so i'm tired of messing with it...
how do i bypass it?? it never gets THAT cold here in cali...
Old Jan 11, 2002 | 07:43 PM
SlowTeg's Avatar
Default Re: How do you bypass the IAC...??? (GSRwBOOST)
Pretty simple. Simply connect the two hoses together with a double sided barbed fitting connecting to the IACV. If you haven't bypassed the TB coolant lines, it's a good idea as well. You can either run a line straight from the thermostat/manifold to the water pipe or just block them both off.
-Mikw
Old Jan 11, 2002 | 10:41 PM
dustin's Avatar
You can always manually do the exact same thing as the IAC valve by using your foot on the right pedal as it warms up Yank it.
Dustin
Old Jan 11, 2002 | 11:52 PM
GSRwBOOST's Avatar
Default Re: How do you bypass the IAC...??? (dustin)
what do i need to do wiht the wires? plug that goes to the IAC??
Old Jan 12, 2002 | 06:47 PM
GSRwBOOST's Avatar
crazybeanery0
Nov 18, 2013 01:11 PM
viking-101
18
Jan 11, 2012 12:42 PM
turbotime
Nov 5, 2005 12:34 AM
mingbling
Mar 21, 2004 06:12 PM
tinkerbell
Jun 25, 2002 01:31 PM
