Question on using torque wrench
Old Jan 11, 2002 | 05:01 PM
HX_Guy's Avatar
Default Question on using torque wrench
When using a torque wrench, are you supposed to set it back to 0 before setting it to the next number?
The techs at my friend's work (Chevy dealer) said that they alwasy do this..and if you dont then the wrench is not accurate.
I sure hope this isnt true, cause if it is..my whole engnine is torqued wrong!
Old Jan 11, 2002 | 05:09 PM
SEFIxCivic's Avatar
Default Re: Question on using torque wrench (HX_Guy)
its true. i wouldn't say it would go bad right away, but if you don't reset the wrench it will need to be recalibrated.
Old Jan 11, 2002 | 05:14 PM
HX_Guy's Avatar
Default Re: Question on using torque wrench (SEFI8LOxCivic)
Well that ******* blows....so my whole engine might be torqued wrong
Old Jan 11, 2002 | 06:04 PM
SEFIxCivic's Avatar
well i dont think thats necessarily true. how long did you leave the wrench torqued for? if its days you might be okay. but if its weeks or months that isnt good. but your buddy is definately right. one time i went to my buddies shop to torque my ring gear and for some reason some bolts were stretching more than others. we ended snapping off the head of a bolt and streching a few others, and it turns out that the snap on wrench was left torqued and gave us false readings. its definately no wives tale.
EK9Tune
17
Jun 11, 2007 12:00 PM
IntegraTypeR
Jul 31, 2006 05:44 PM
Junkyard2000
Jan 15, 2006 10:00 PM
92hatchattack
Jul 19, 2004 08:53 PM
HX_Guy
Jan 12, 2002 10:58 AM
