how much boost?
Old Jan 5, 2002 | 12:18 PM
11secdx's Avatar
Default how much boost?
with a completely built bottom end, how much boost can i run, with a stock ecu? car is a 96 integ gsr.
Old Jan 5, 2002 | 12:20 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: how much boost? (11secdx)
Now, why would you want to use a stock ecu with a built bottom end?
Old Jan 5, 2002 | 12:29 PM
11secdx's Avatar
Default Re: how much boost? (Arturbo)
i'm running out of money. until next xmas. i do have a apex Vafc. it ran safe and strong on 10 psi.
Old Jan 5, 2002 | 12:30 PM
jinxproof99's Avatar
New User
why does everyone wanna now "how much boost". your question should be "how much horsepower"?
18 lbs on a t4 sustains/makes way more power than a small t3/4 w/ 18 lbs.
using anything higher than 550cc injectors on a stock ecu is not recommended(with afc/fmu). that limits you to around 400 hsp to the wheels, give or take.
Old Jan 5, 2002 | 12:33 PM
11secdx's Avatar
Default Re: how much boost? (jinxproof99)
to make HP, i need to know how much boost i can run on a stock ecu.
Old Jan 5, 2002 | 12:34 PM
Arturbo's Avatar
Better than steak
25 Year Member
The stock ecu cant read boost.
Old Jan 5, 2002 | 12:38 PM
New User
ok, so if i say you can run 1.5bar on a stock ecu and motor, how does that help you??
Old Jan 5, 2002 | 12:56 PM
11secdx's Avatar
i do apoligize. my question should have stated. whats the biggest injector size, i can run with a stock ecu? after knowing this, i will need to ask " how much boost can i run on that injector size?"
Old Jan 5, 2002 | 01:13 PM
New User
440cc injectors are relatively easy to tune. the 550's will require the dyno without a doubt. we would still need to now what turbo your going to run to give you a boost level. also, the finer you tune the engine, the less boost you'll need to run to get a given amount of power. for instance....i may get 350hsp from a t3/4 @ 20lbs of boost. someone else may get 350 hsp from the same t3/4 @ 16lbs of boost. one motor is closer to destruction than the other.
Old Jan 5, 2002 | 03:52 PM
turbotypeR@SPEC's Avatar
25 Year Member
i have 440cc injectors and can make about 22lbs of boost=434whp.
Old Jan 5, 2002 | 05:20 PM
FAST94GSR's Avatar
New User
Default Re: how much boost? (turbotypeR)
wish my car made 434 hp @ 22psi..
Old Jan 6, 2002 | 11:06 AM
SlowTeg's Avatar
Just because a motor is able to push more power out of a lower boost level doesn't necessarily mean that it's closer to destruction than the other. As long as there's plenty of fuel and there's a conservative timing map it's perfectly safe. Different mods and configurations can affect the amount of hp as well.
-Mike
Old Jan 6, 2002 | 11:32 AM
11secdx's Avatar
thanks turbotyper, thats what i was kinda wanting to here.
SpoonMotorSport
Engine Management and Tuning
Aug 1, 2011 06:19 PM
ilovemyb16a
Dec 7, 2006 09:40 PM
mrx
Jul 29, 2004 11:02 AM
Arch-Angel
Sep 17, 2003 06:41 PM
boosted spoon
Jun 5, 2002 09:45 AM
