How to run 12's on a Type R??..NEED HELP
Old Jan 5, 2002 | 04:27 PM
hYpE-R-29's Avatar
Default How to run 12's on a Type R??..NEED HELP
i posted this in the Type R forum, so heres the situation..i recently came into some money and am deciding to build my car to run 12's...I dont want turbo because they are hard to maintain...so i was thinking about JRSC..i need plenty of suggestions on a good setup..thanx
Old Jan 5, 2002 | 04:46 PM
schwett's Avatar
New User
Default Re: How to run 12's on a Type R??..NEED HELP (hYpE-R-29)
i know of one guy running 12s on an itr w/jrsc, but it took a lot of work to get there.....
Old Jan 5, 2002 | 05:18 PM
FAST94GSR's Avatar
New User
Default Re: How to run 12's on a Type R??..NEED HELP (schwett)
you could throw a 80 shot of nos run a set of slicks and you'll do 12's. superchargers arent' worht the money spent. turbos are the best way to go imo. take a drive in a turbo car and you'll never look back at anything again.
Old Jan 5, 2002 | 05:19 PM
csufweed's Avatar
yeah it takes some work to do 12's with an ITR... I'd say go all motor. I've seen it done before... I assume the jrsc will make getting there a lil easier, BUT it will still be hard... high compression needs to be taken care of but I assume doing that will be enough to turbo the B18C5 safely. that would probably the easiest and simplest route towards 12's in an ITR.
Old Jan 5, 2002 | 05:31 PM
TurboIntegra's Avatar
Default Re: How to run 12's on a Type R??..NEED HELP (csufweed)
Well I know you dont like turbo but..........
I have
00 Type R
Drag Gen III Turbo Kit
Hondata standalone ecu
stock block w/ headgasket to lower compression
and all the other generic turbo things.... 3"exhaust, boost controller etc.
I ran high 12's on street tires!
No offense I am not a fan of JRSC They are pretty weak.
I have had no problems with my turbo setup. Just my $.02
Old Jan 5, 2002 | 05:57 PM
Type-ARR's Avatar
12's with a JRSC ........lol i like to see that....
Old Jan 5, 2002 | 06:00 PM
immortal's Avatar
Banned
Default Re: How to run 12's on a Type R??..NEED HELP (ITR-481)
umm why dont you look in the type-r forum
i cant think of his name right now ..i'm having a mental block. mike something? type-r is like 230-240hp to the wheels he's in the 12's on a jrsc...
got his name : https://honda-tech.com/zerouser?cmd=viewprofile&id=534
Mike Marsey
'98 ITR #0717
Supercharged!
264whp 170trq
Member of the 12sec club w/2750lbs (street-setup)
The dark side is getting stronger...
For all JRSC type R info go to my site @ http://www.geocities.com/superchargedtyper
For the best dynotuning: http://www.dynospotracing.com
thats his sig
[Modified by immortal, 7:05 PM 1/5/2002]
Old Jan 5, 2002 | 10:28 PM
PureTeg420's Avatar
Default Re: How to run 12's on a Type R??..NEED HELP (immortal)
yeah go ahead and ask him how much he spent on his car to run that 12.9, with that much $$ he could have been in mid 11's with turbo
Old Jan 5, 2002 | 10:30 PM
FCdrifter's Avatar
New User
Default Re: How to run 12's on a Type R??..NEED HELP (PureTeg420)
and we could all be in the 10s if we had 5.0's its all relative. Seriously type r imo should be kept n/a its what is was amde for.
Old Jan 5, 2002 | 11:02 PM
PureTeg420's Avatar
Default Re: How to run 12's on a Type R??..NEED HELP (96greengsr)
yeah everyone knows mustang GT will run 10's, thanks to that kick *** 5.0. He didn't ask for your opinion on what the Type R was made for, he asked how to get it into 12's. to hit 12's... n/a= the most money, jrsc is next, then turbo, then nitrous....
Old Jan 6, 2002 | 12:12 AM
DIRep972's Avatar
Smarter than you
12's in an ITR is pretty simple.. direct port 100 shot, rods, pistons, IHE, id say use a CAI, a header w/ a 2.5 inch collector, and maybe even leave the exhaust stock but get a high flow cat.. and 500 for some slicks and if you can drive you should break 12's.. then you would probably want an AFC and cams and you would be looking at about 4k dollars...
seriously if you want to be ***** to the walls fast you can only accomplish that with a turbo.. and youd be suprised how much more simple turbo is then NA.. just do a turbo kit w/ hondata and a lower compression headgasket... youll haul ***
Old Jan 6, 2002 | 12:37 AM
Mista Bone's Avatar
D Tranny Guru
80 shot + 22x8x15 slicks, 12.8 all night long.
Old Jan 6, 2002 | 01:10 AM
schwett's Avatar
New User
Default Re: How to run 12's on a Type R??..NEED HELP (Mista Bone)
heh heh heh heh heh lol
Old Jan 6, 2002 | 09:32 AM
TurboITR's Avatar
all night long.
until the bottle runs out...
Old Jan 6, 2002 | 10:19 AM
b18cTurbo's Avatar
Default Re: How to run 12's on a Type R??..NEED HELP (TurboITR)
i ran 100 shot on my b18c5 FUULLLLL STOCK only msd whit blaster coil,
made 13.7@109.5mph my ET was not good cuz i had no slick(195.50.15 yokohama 520) and i didint press juice on first gears but look at trap speed!!!could do easy 12.5 on slick
ran 75 shot all summer whit no prob the key is tuning and ignition upgrade(a must when nos)
that was on my civic ex coupe 2000 full int!!
so conclusion a itr and a civic ex whit c5 has almost same weight maybe 10 killo diffence so yes itr whit 100 shot whit msd can do easy 12 midle!!!!!
Old Jan 6, 2002 | 02:08 PM
jinxproof99's Avatar
New User
Default Re: How to run 12's on a Type R??..NEED HELP (TurboIntegra)
I have
00 Type R
nice. yeah, what you said.
nblock93
Feb 14, 2005 04:27 AM
YashiMotors
Apr 14, 2004 12:41 PM
vteckiller
Jul 15, 2002 05:19 PM
gina
Jul 7, 2001 09:36 AM
