is this block clean enough?
Old Jan 7, 2002 | 09:30 PM
VaporTrail's Avatar
New User
Default is this block clean enough?
Golden Eagle sleeved B18c block bored to 84.5mm. Just thought I'd show off how clean it is
Old Jan 7, 2002 | 09:32 PM
NWPNOMORE's Avatar
Banned
Default Re: is this block clean enough? (VaporTrail)
it might not but be clean enought to eat off of, but it still looks dam clean
Old Jan 7, 2002 | 09:34 PM
integra7's Avatar
New User
good god that looks nice!
Old Jan 7, 2002 | 09:44 PM
stizzit's Avatar
Default Re: is this block clean enough? (NWP4LIFE)
i'd eat off it, hell i'd screw on it too! (might not be so comfortable)
Old Jan 7, 2002 | 09:50 PM
NWPNOMORE's Avatar
Banned
Default Re: is this block clean enough? (stizzit)
haha
Old Jan 7, 2002 | 10:04 PM
DIRep972's Avatar
Smarter than you
splooge! I want one too!
Old Jan 7, 2002 | 10:34 PM
VaporTrail's Avatar
New User
Default Re: is this block clean enough? (DIRep972)
well you too could have one. http://www.goldeneaglemfg.com for the sleeving, then send it to me for the cleaning
Old Jan 7, 2002 | 10:56 PM
Turbo00's Avatar
New User
what head gasket are u going to use for a 84.5mm i dont think cometic makes a 84.5. or do u just use the 84mm one
Old Jan 7, 2002 | 10:57 PM
VaporTrail's Avatar
New User
Default Re: is this block clean enough? (Turbo00)
mine is 85mm cometic. too small of a difference to matter.
Old Jan 8, 2002 | 01:13 AM
Ray's Avatar
Ray
New User
John,
Nice job cleaning the block , When my block came back from golden eagle, it looked more dirty than before. I guess they dont jet-clean the blocks. How much do you charge to clean an engine? just curious
Old Jan 8, 2002 | 06:10 AM
29psiHybrid's Avatar
Default Re: is this block clean enough? (Ray)
My block is going to GE this week. Why did you go with 84.5mm vs 84? I was planning on going 84. Also what is this cometic head gasket you're referring to? They told me to use a Honda gasket and dremel the opening to size. What did you use to clean your block? Got any better pics of the sleeves? Thanks
Old Jan 8, 2002 | 06:53 AM
redline's Avatar
Default Re: is this block clean enough? (9psiHybrid)
but you are putting all those dirty mounting brackets back on?
nice block, soon enough i will have one like it
Old Jan 8, 2002 | 08:18 AM
bigTom's Avatar
Default Re: is this block clean enough? (redline)
i painted my block... actually came out pretty nice... u can do that as well
Old Jan 8, 2002 | 08:26 AM
HX_Guy's Avatar
What are those two "nipples" on the back of the block?
Old Jan 8, 2002 | 09:21 AM
newsense's Avatar
New User
Default Re: is this block clean enough? (HX_Guy)
how did you get it so clean???? sand/bead blasting perhaps?
Old Jan 8, 2002 | 09:48 AM
VTC_CiViC's Avatar
Default Re: is this block clean enough? (newsense)
Glass beating I bet..
Old Jan 8, 2002 | 10:10 AM
VaporTrail's Avatar
New User
I was only kidding, I don't clean blocks for money
A long time ago, on my old setup, I had it bead blasted. It looked better than new! But after that setup blew, removed it, broke it down, and sent it to GE, it got pretty dirty again.
To clean it, I used Aluminum Aircraft Paint Stripper. It's a paint stripper designed for aluminum, as the name states. You can pick up various brands of it at any autoparts store. All I did was spray it on nice and thick, and let it sit for 3-5 minutes, scrubbed with a wire brush for the really dirty areas, then rinse. Make sure you where gloves when you do this, as it uses the same **** that removed tile flooring, pretty nasty stuff. When you spray it on, it actually foams and turns gelatinous, and has the consistancy of, well, use your imagination. It will chemically burn your hands though, so be careful.
After rinsing, simply blow it dry with compressed air. Voila! Done
Old Jan 8, 2002 | 10:14 AM
VaporTrail's Avatar
New User
One thing at a time. I was thinking of painting them black, or perhaps silver to match. It's a minor detail yet, I have a lot of major ones yet to take care of.
Old Jan 8, 2002 | 10:20 AM
VaporTrail's Avatar
New User
I went with 84.5mm b/c that is the size of my pistons that I had available to me from Endyn. You should be fine going with 84mm.
Cometic is a maker of gaskets and such for motorcycles, really high quality stuff. They are now doing import head gaskets also. I am using a GSR block, with the oil passage in the block. So, I couldn't use a Honda head gasket without modifying it. Cometic makes a large bore VTEC block head gasket, with the proper location for the oil passage and dowel pin locations. It's a tri-metal gasket, just like the OEM gasket, stock thickness and all. I would definately recommend it, it's a real nice piece, and priced at about 65 bucks. I got mine from Endyn, but if you're a hater, you can also get it from http://www.raceeng.com.
Here's a better pic of the sleeves:
Old Jan 8, 2002 | 10:31 AM
VaporTrail's Avatar
New User
Remember, this is a GSR block, which has an oil cooler. Thats one of the feed lines for the coolant to the oil cooler. The other is apart of the PCV system.
Old Jan 8, 2002 | 10:57 AM
98hx99b18c's Avatar
I think you missed a spot...j/k..Looks really good!
-How much did they do the sleeves for, did you get it on the groupbuy?
Old Jan 8, 2002 | 11:03 AM
Ray's Avatar
Ray
New User
Default Re: is this block clean enough? (98hx99b18c)
does home depot have aluminum aircraft paint stripper?
edit: n/m i saw the "any autoparts store" guess i'll buy some for my tranny.
[Modified by Ray, 8:19 PM 1/8/2002]
Old Jan 8, 2002 | 11:09 AM
Arturbo's Avatar
Better than steak
25 Year Member
You missed a spot..
Old Jan 8, 2002 | 11:46 AM
VaporTrail's Avatar
New User
Default Re: is this block clean enough? (Arturbo)
it's still way cleaner than most, I can live with a spot.
Old Jan 8, 2002 | 07:30 PM
I don't understand. You said you are using a GSR block with the oil passages in it so you couldn't use the Honda gasket without modifying it. What head are you using? And why won't it work? Thanks for the pic.
