in-line pro headgasket question
Old Jan 7, 2002 | 05:48 PM
SoloSol's Avatar
Default in-line pro headgasket question
Whats the thickness of their gsr gasket. Do they make one that dosent lower the cr? How much crush is there? I've heard good things about them, just not needed one till now. Thanks.
Old Jan 7, 2002 | 06:03 PM
Jared's Avatar
Default Re: in-line pro headgasket question (SoloSol)
Excellent product, I used one for a long period of time before a dropped valve destroyed that motor. Not sure about thickness, advertised to drop compression a full point. AFAIK, they don't make one that doesn't lower c/r because their product that does lower c/r is simply a Honda headgasket with the middle layers removed and replaced with a copper section thick enough to lower the c/r 1 point.
Old Jan 7, 2002 | 06:09 PM
SoloSol's Avatar
Default Re: in-line pro headgasket question (Jared)
Cool! So if I was building a motor for a specific c/r, I would go 1 point higher on the pistons.. 10:1piston+inline gasket=9:1 c/r
Old Jan 7, 2002 | 06:15 PM
sgT's Avatar
sgT
If you are building a motor for a specific compression you should just get the
pistons that will give you that compresison ratio rather than use a head
gasket.
Old Jan 7, 2002 | 06:21 PM
SoloSol's Avatar
Default Re: in-line pro headgasket question (sgT)
I'm sorry I think I was not being clear. I am going with an ls/vetc with 83mm bore and may need a head gasket to fit that bore size. I only know of inline who says they can make a custom one so thats why I was talking of using their gasket.
Old Jan 7, 2002 | 06:29 PM
sgT's Avatar
sgT
Why 83mm??
You arent going to do this on stock sleeves are you?
With or without an inline gasket you'll still need to make a stock gasket 83mm to
fit to it.
Old Jan 7, 2002 | 08:29 PM
Adi Radoncic's Avatar
On Fire!
Hey
The Inline pro head gasket is 2.7mm thick but in your situation I wouldn't use it.
If you want a nice good quality gasket try http://www.cometic.com/
and they should be able to provide you with customs, but don't take my word for it.
Just call and see.....
Adi
ben h
15
Apr 24, 2012 01:08 PM
vajdmeg
Jan 30, 2009 11:01 AM
pootie.teng
18
Mar 6, 2007 03:23 PM
jfboy
Dec 27, 2004 10:09 AM
Charlie Moua
Mar 19, 2003 06:12 AM
