Good turbo piping?
Old Jan 11, 2002 | 06:25 PM
SpeedracerS4's Avatar
Default Good turbo piping?
My friend recently wreck his car, and he's selling his drag 3 turbo kit. I want to buy it, but it doesnt have the piping. Anyboday know where I can get just a complete turbo pipings?? TIA
Old Jan 11, 2002 | 07:30 PM
TurboSedan's Avatar
New User
Default Re: Good turbo piping? (SpeedracerS4)
Pimp master Ben sells piping! Hit him up!!
Old Jan 11, 2002 | 08:05 PM
Honda Hick's Avatar
You can go the cost effective PVC piping route
Old Jan 11, 2002 | 10:32 PM
LSturboHB's Avatar
Default Re: Good turbo piping? (Honda Hick)
PVC WORKS FUR M3
Old Jan 11, 2002 | 10:36 PM
dustin's Avatar
Default Re: Good turbo piping? (LSturboHB)
Use mandrel bends from your local performance shop.
Dustin
Old Jan 12, 2002 | 09:30 AM
Giuseppe's Avatar
at underhood temperatures, would u want choking fumes entering your lungs
when PVC is heated it emits toxic fumes.. very bad for motor, and car..
i agree with dustin..
hth
[Modified by Giuseppe, 6:31 PM 1/12/2002]
Old Jan 12, 2002 | 02:05 PM
LSturboHB's Avatar
Default Re: Good turbo piping? (Giuseppe)
TOXIC FUMES , what hell ??? you a scientist. maybe thats why my car runs so perfect with 208whp on a stock LS.
Old Jan 12, 2002 | 02:09 PM
zojirushi's Avatar
he's not joking. heating pvc isn't a joke. I'd replace it if i were you
Old Jan 12, 2002 | 06:27 PM
ZColeon's Avatar
New User
Default Re: Good turbo piping? (97CivicFerio)
Pimp master ben huh..
Old Jan 12, 2002 | 06:50 PM
boomslang's Avatar
The recommended operating temperature of PVC is capped at around 150 degrees. PVC emits dioxins when heated to high temperatures. Dioxins are extremely harmful. http://www.who.int/inf-fs/en/fact225.html
Old Jan 12, 2002 | 07:35 PM
Arturbo's Avatar
Better than steak
25 Year Member
that is correct.
Old Jan 12, 2002 | 08:22 PM
csufweed's Avatar
Default Re: Good turbo piping? (Arturbo)
muffler shop, aluminized steel piping, mandrel bent
Old Jan 12, 2002 | 08:23 PM
csufweed's Avatar
Default Re: Good turbo piping? (csufweed)
stainless is even better!
Old Jan 12, 2002 | 11:06 PM
Giuseppe's Avatar
why are some people here so quick to judge..??
you a scientist.
Old Jan 12, 2002 | 11:11 PM
turbocoupe's Avatar
you a scientist. $$
doesn't matter where you go. . .you'll always find someone quick to judge.
Old Jan 14, 2002 | 12:05 PM
dustin's Avatar
Default Re: Good turbo piping? (turbocoupe)
PVC is poly vinyl chloride so ... it emits cancer-causing gas when heated. Can't be good for your motor. PVC is for water and stuff.
Dustin
Old Jan 14, 2002 | 01:15 PM
SiR Kid's Avatar
New User
Default Re: Good turbo piping? (dustin)
buy some piping from JC Whitney.... They sell mandrel bends any size... get quite a few and a welder... instant boost piping
Old Jan 14, 2002 | 02:40 PM
TurboSedan's Avatar
New User
Default Re: Good turbo piping? (SiR Kid)
They used to store old valuable coins in PVC, then they realized it released gas that reacts with the metal and combines to eat away at the coin. DOH!!
Old Jan 14, 2002 | 02:41 PM
falcongsr's Avatar
What is this crap?
Dustin
i doubt the gas emitted does anything to the motor whether its inert or not, i doubt it messes anything up. its not in any significant quantities, unless he PVC is on fire/melting.
if it is indeed inert, then the cancer causing gas is coming out your tailpipe. that just sucks. get metal.
Old Jan 14, 2002 | 03:49 PM
dustin's Avatar
Default Re: Good turbo piping? (falconGSR)
Well, pollutants that get in the combustion chamber get in the oil. Why cheap out... steel cannot be much more expensive than pvc... and with steal at least you will not look like a moron with water pipes for IC piping
Dustin
Old Jan 14, 2002 | 07:09 PM
TurboSedan's Avatar
New User
Oh how very true, that would look so fugly.
Old Jan 14, 2002 | 08:13 PM
Giuseppe's Avatar
"inert" means non-reactive...
these gases are indeed reactive, dioxins are readily absorbed into the body,causing all sorts of ailments...
over time (and this is what i think) these superheated droplets of PVC will eventually build up into some sort of gunk in your motor...
but then again who am i to say....??
any comments..??
Old Jan 14, 2002 | 10:58 PM
93LSivic's Avatar
I got really sick and puked for a coupleof hours after working with PVC. Back when I was doing car stereo I was using them as ports for sub enclosure (common practice), I was rounding them with a router that had a worn bit and it smoked the plastic. I inhaled it and got sick soon after.
I couldnt even imagine what kind of temps are coming from the compressor before the IC? And I bet that the toxins released from it would have something to do with how the air/fuel mixture ignites inside the combustion chamber. , it may burn at a higher temperature and cause major detonation! I wouldnt with it. Dont be a cheap *** and buy that crap, hell your puttin the moeny into doing FI on a motor that wasnt meant for it, its already got enough stress as it is--do yourself, the guy behind you in traffic, and Bambi who's frolicking around in the nearbye wilderness a favor. BUY METAL IC PIPING!!!
kholmes
Dec 24, 2004 09:15 AM
boostedbar
16
Jul 4, 2003 06:32 PM
turbotime
Jun 28, 2003 09:47 AM
InfamousRS
Jan 25, 2002 05:29 AM
