Fuel pump ?s.....greddy blue box?s
Does the blue box adjust fuel like a FMU would? If not, how does it dump more fuel into the motor? I'm currently looking at an intank walbro high pressure for boosting 8psi on a greddy kit (d16z6). Down the road I may go FMU when I decide I want to boost more so I'll consider an inline pump then. But as far as preference, it really doesn't matter...... I'll get the pump that works out better.
So, with 8psi on a greddy civic kit, would a walbro 255 high pressure be fine....or inline? BTW I have done a search on this and it helped a lot. I just couldn't find anything specific with the blue box. Thanks.
Re: Fuel pump ?s.....greddy blue box?s (5thgen)
the blue box adds fuel by sensing boost using the factory map sensor and increasing the injector pulsewidth accordingly. it also sends a fake map signal to the stock ecu so you won't throw any codes. it works fairly well until you try to boost too much and melt a piston, like i did.
as far as the fuel pumps go, you only need a high pressure pump if you are planning to go the RRR/FMU type setup. if you are planning on larger injectors, the you only need a high-flow pump, and, of course, something to tune the injectors.
i would be wary of running high fuel pressures to meet fuel requirements, but it does the job.
Re: Fuel pump ?s.....greddy blue box?s (downpipe)
what are the wiring differences with using the blue box on the 96+ civic ex's. I heard there are some but i cant' remember where i got the info from. Or is it just better to use a missing link with a FMU
Re: Fuel pump ?s.....greddy blue box?s (willyboyD16)
He has the diagrams for wiring up the blue box for 96+ civics.
Re: Fuel pump ?s.....greddy blue box?s (snt78)
If your in the market for a high pressure walbro i have one that is barly used for sale. It is the one from Holley for forced induction. Ill let it go for 75 bucks shipped.
Boosted3g@aol.com
Boosted3g@aol.com
boostincoupe
03-05-2004 08:04 AM
boostincoupe
05-09-2003 10:33 PM
SiBirdie
09-28-2001 09:31 PM
