nitrous on a turbo LS
Old Jan 4, 2002 | 06:37 PM
311's Avatar
311
Default nitrous on a turbo LS
I have a turbo LS integra and wanna put nitrous on it as well. its a dry zex kit, and i need to know were to tap the piping, and if its worth it.
Old Jan 4, 2002 | 07:06 PM
Drag III Integra's Avatar
Default Re: nitrous on a turbo LS (boostedteg)
hmmm
Old Jan 4, 2002 | 08:20 PM
DR. ON POINT's Avatar
Banned
ur gonna **** some **** up man
Old Jan 4, 2002 | 10:21 PM
Type-ARR's Avatar
Default Re: nitrous on a turbo LS (On Point EK)
tap into the innercooler, just make sure you got the fuel to back it......
Old Jan 4, 2002 | 10:37 PM
DIRep972's Avatar
Smarter than you
not worth it in my opinion, now a fogger system for the intercooler would be bad *** but figure if your cars motor and fuel system is ready to add nitrous, its more then ready to add more boost.. just turn up the boost dude(if the car can handle it)
Old Jan 5, 2002 | 07:06 AM
Default Re: nitrous on a turbo LS (DIRep972)
ok now do you tap before the intercooler or after the intercooler
Old Jan 5, 2002 | 10:53 AM
IMPATIENT's Avatar
Default Re: nitrous on a turbo LS (Drag III Integra)
hope you got a fully built motor bro cause otherwise BABOOOMMM....is all your gonna hear........
Old Jan 5, 2002 | 05:16 PM
FAST94GSR's Avatar
New User
Default Re: nitrous on a turbo LS (IMPATIENT)
tap it after the intercooler. throw a 50 shot on it. curious to see how well your car will hold up. hopefully its built but if not oh well its not my car!
Old Jan 5, 2002 | 05:24 PM
csufweed's Avatar
Default Re: nitrous on a turbo LS (FAST94GSR)
DO NOT try to inject nitrous into your engine!
Simply rig up the nozzles to spray nitrous in front(on the exterior) of the intercooler to cool down the intake charge even more. This is the only safe solution to using nitrous with turbos without a lot of work or worries.
[Modified by csufweed, 2:27 AM 1/6/2002]
Old Jan 5, 2002 | 05:36 PM
DLB1994's Avatar
Default Re: nitrous on a turbo LS (csufweed)
i have nitrous the NOS brand on my car with turbo the dry kit i tap it right in front my TB a 50shot it will knock off 1 full second at the track just make sure u don't run lean if u have an AFC just richen it up in the high rpm's and make sure u retard your timing
Old Jan 5, 2002 | 06:47 PM
311's Avatar
311
Default Re: nitrous on a turbo LS (DLB1994)
i was planning on running a 55 dry shot right befoe the IC, but i might just sell the kit and bump the boost up
Old Jan 6, 2002 | 12:22 AM
bump up the boost jan 26.
patrick4588
Mar 19, 2007 01:59 PM
nitroeg
Oct 20, 2005 03:15 PM
2000civicsi61
Sep 21, 2003 06:59 PM
egturbo
Jan 16, 2003 11:04 PM
